Takeda CAI Sound Clip - 2015 RC350 F-Sport
#47
Here is a link to briefly describe the difference between the two:
http://www.autoanything.com/air-inta...y-filters.aspx
#49
The oiled filter actually flows more than the non-oiled one. The oiled CAI is also much better at filtering out particles.
Also,when in "no enclosure" filter is installed it's always beter to have oiled filter...collects more fine particles (exactly what Gearhead said in previous post)
#50
Danggg...it's insane man
I was done with install in 30 min and tested the car right after that.
S+ and from second to third gear,right around 4000-6000RPM...IT ROARS AND GROWLS.
Combo of CAI & exhaust is insane.
Also,it might be a placebo now but somehow I feel way more "pull" now!!!
It jumps
It jumps
#51
It jumps
It jumps
#52
#53
Absolute power & awesome sound !!!
Combo of exhaust & CAI is match made in heaven.
I just don't have time to set up my camera on dashboard to do a video like you did...or to record "Kenny passing by a camera" for a fly by video.
Maybe one of these weekend I'll do just that.
#55
#56
Hey GearHead car sounds great, is it true that it is possible to gain about 5 hp through the installment of the cold air intake, are you aware of this being tested on a dyno for the RC 350 ?
I've heard people losing a few hp due to the fact the the factory air rate of entry is dialed in to flow with other processes of the engine and you can lose some power down low but gain a few hp up high. But this is dependent on the vehicle, some cars it works and some it does not.
What kind of exhaust system do you have ?
I just chopped out the muffler and it sounds incredible, so i was thinking exactly what you did, a cold air intake and an exhaust modification combo. Looking forward to hearing what your ride sounds like.
#57
Right now I have the stock RC exhaust, but that will change when I'm off for 2 weeks at Christmas. I'm going to have the rear mufflers taken off and a new bolt on pipe put on the resonator to the stock tips. This way if I or more import the wife doesn't like the sound all I need to do is unbolt the pipe and put on the stock mufflers with stock tips.
If you already listened to the sound clip of the CAI that I posted that is what my car sounds like with just the CAI. I can only image what it would sound like with the mufflers cut out and the CAI.
#58
GearHead69, have you noticed and increase in fuel economy with the CAI? When I installed one in the RSX I noticed about a 10% increase when I wasn't stepping on it.
#60
