Key Fob
2015 RC Manual (P. 590)
To take out the mechanical key, push
the release button and take the key out.
The mechanical key can only be
inserted in one direction, as the key only
has grooves on one side. If the key cannot
be inserted in a lock cylinder, turn it
over and re-attempt to insert it.
After using the mechanical key, store it
in the electronic key. Carry the mechanical
key together with the electronic key.
If the electronic key battery is depleted
or the entry function does not operate
properly, you will need the mechanical
key. (P. 590)
key. (P. 590)
Really? How often would you need to use the mechanical key? I never once needed it in 7 years of ownership of an IS250.
The problem with making a seldom used task convoluted and difficult is that when you need to do it, you forget how. As I read through my manual about the key, I found that, even with the directions in front of me, it's difficult to do. I practiced a few times, but two years from now, when I need to get that key out for some reason, I'm sure I'll forget how. What was so wrong with a square key for the ignition and a round key for the trunk?
I don't think we do. I have locked a glove box in my car perhaps 3 times in the past 20 years, and I didn't have to. What do you keep in your glove box - expensive gloves?
No, I never have. All I keep in the glove box is the user manual and a few CDs. You can lock any valuables in the boot/trunk without the key.
Haha, what good is locking valuables inside the trunk when the valet has access to the key and switch to get inside of it? In your glove box is a button to disengage the trunk so it wont open regardless if you hit the trunk button on the fob or to the left of the steering wheel. You hit the button, lock the glove box and bam! Locked trunk. I trust no one.
OK, 10 lex. That and expensive gloves are two good reasons to use the manual key.
While we are on the subject, I found that the user manuals take up almost all the room in there and are seldom used. I moved and secured them in a corner of the trunk to make more room for my gloves and other things I like to keep handy (V-1). For those with an iPad (isn't that everybody here), the manuals are available as PDF downloads, which saves lots of room for those who travel with an iPad all the time. Pilots are doing this with all their documents, why shouldn't we try the same thing?
