Test Signature Banners Here (MAX: 450 x 100 px, less than 50kb)
Old 07-06-03, 01:07 AM
futuregs
futuregs's Avatar
Exclamation Test Signature Banners Here (MAX: 450 x 100 px, less than 50kb)
People,
Please test your new sigs in this thread....
Thanks You,
--Brandon
Attached Thumbnails Test Signature Banners Here (MAX: 450 x 100 px, less than 50kb)-futurejuly.jpg
futuregs is offline
Old 07-06-03, 01:08 AM
futuregs
futuregs's Avatar
mrsypher July03':
Attached Thumbnails Test Signature Banners Here (MAX: 450 x 100 px, less than 50kb)-july03-1.jpg
futuregs is offline
Old 07-06-03, 01:09 AM
futuregs
futuregs's Avatar
mrsypher July03:
Attached Thumbnails Test Signature Banners Here (MAX: 450 x 100 px, less than 50kb)-july03-2.jpg
futuregs is offline
futuregs
futuregs's Avatar
mrsypher July03
Attached Thumbnails Test Signature Banners Here (MAX: 450 x 100 px, less than 50kb)-july03-3.jpg
futuregs is offline
Old 07-06-03, 08:25 AM
MrSypher
MrSypher's Avatar
Hey, I have one question for anyone that knows the answer.....
WHO'S THE FRIGGIN MAN?????
MrSypher is offline
Old 07-07-03, 03:52 PM
2jzgte
2jzgte's Avatar
You unstickied my sticky. Bastards.
2jzgte is offline
Old 07-07-03, 04:06 PM
2jzgte
2jzgte's Avatar
Here Southern Sun GS. Your lights. Tell me if it's tacky. I want harsh comments.
Attached Thumbnails Test Signature Banners Here (MAX: 450 x 100 px, less than 50kb)-12696signature-copy.jpg
2jzgte is offline
Old 07-07-03, 07:48 PM
MrSypher
MrSypher's Avatar
I need some help... How do I save those sigs a JPEG's?? When I go to save them they get saved as Bitmap's and I can't switch them... HELP....
MrSypher is offline
Old 07-07-03, 07:58 PM
DaveGS4
Forum Administrator
Administrator
DaveGS4's Avatar
Received 2,312 Likes on 1,410 Posts
Mr S, sounds like you're having the same problem I did not long ago... couldn't save anything other than as a bitmap when doing a right click, save as.
Found a solution (pasted in below) that worked for me:
RESOLUTION
To troubleshoot and resolve this behavior, empty the contents of the Temporary Internet Files folder, and then DELETE THE FILES IN THE DOWNLOADED PROGRAMS FOLDER that are listed as either UNKNOWN or DAMAGED. To do so:
Start Internet Explorer (if it is not already started).
Empty the contents of the Temporary Internet Files folder. To do so:
On the Tools menu, click Internet Options.
Click the General tab.
Under Temporary Internet files, click Delete Files.
When you are prompted to delete all temporary Internet files, click OK.
In the Downloaded Program Files folder on your hard disk, remove the files that are listed as either Unknown or Damaged. To do so:
Under Temporary Internet files, click Settings.
Click View Objects.
The list of program files that are downloaded to the SystemRoot\Downloaded Program Files folder on your hard disk appears in the Downloaded Program Files window.
In the Status column, note the files that are listed as either Unknown or Damaged. Remove these files. To do so, right-click the file, and then click Remove.
When you are prompted to confirm the removal, click Yes.
Close the Downloaded Program Files window, and then click OK two times.
Save an image in Internet Explorer to test and determine if the issue is resolved.
If the issue continues to occur after you remove all downloaded program files that are listed as Unknown or Damaged, try removing the other downloaded program files that are on the list.
Note: The next time that you need one of the files that you removed from the Downloaded Program Files folder, you will receive a prompt to download the file to your hard disk in Internet Explorer.
Found the info here
DaveGS4 is offline
Old 07-08-03, 03:14 PM
MrSypher
MrSypher's Avatar
Damn Dave!! Thanks for the write-up, I do appreciate it.. I don't have time right now to attempt this but I will later.. Thanks again...
MrSypher is offline
Old 07-08-03, 05:19 PM
2jzgte
2jzgte's Avatar
I have a two minute solution, that works with most pics. Right click image and view as, it should open up in a new window as a JPEG.
2jzgte is offline
Old 07-14-03, 10:45 AM
sniper5
sniper5's Avatar
bb
sniper5 is offline
Old 07-17-03, 03:07 PM
ATSOU
ATSOU's Avatar
Test 1:
Attached Thumbnails Test Signature Banners Here (MAX: 450 x 100 px, less than 50kb)-sd04.jpg
ATSOU is offline
Old 07-21-03, 03:15 PM
adidosc
adidosc's Avatar
well nothing special, but i took a shot i had from after an ice storm this past winter...
adidosc is offline
Old 07-24-03, 06:05 AM
Belshe1993
Belshe1993's Avatar
Default test
Belshe1993 is offline
Quick Reply: Test Signature Banners Here (MAX: 450 x 100 px, less than 50kb)
