Picture - Link Question
Old 10-20-02, 04:25 PM
///MDex
///MDex's Avatar
Default Picture - Link Question
Is it possible, to have a sig (picture) a composite picture of other pictures, with imbedded links as the compositite pics?
Like, what I want to do is have a sig pic that can have a listing of links like, my page, the cl rules, the cl diy page, each as their own pic/link inside the sig pic.
I'm gonna start playing around in PS now, but not sure of its even possible, hence, my question to the experts.
///MDex is offline
Old 10-20-02, 04:56 PM
futuregs
futuregs's Avatar
You mean seperate image files per link or one big image with the links incorporated into it? If you mean one giant pic you can do it by creating an image map.
futuregs is offline
Old 10-20-02, 05:00 PM
///MDex
///MDex's Avatar
Originally posted by futuregs
...one big image with the links incorporated into it....you can do it by creating an image map.
Yeah. How do I create an image map?
///MDex is offline
Old 10-20-02, 05:09 PM
futuregs
futuregs's Avatar
I use a webpage designer - Macromedia Dreamweaver and then you can highlight the areas you want to become "clickable" and then link them to the webpage.
Im pretty sure you can use Frontpage also.
And if you know HTML code you could write it yourself...lol.
futuregs is offline
Old 10-20-02, 10:09 PM
LexusRules
LexusRules's Avatar
he means to do it for our sigs, i had it before. all seperate images.
dex my suggestion to you is open up PS and just select a peice and cut it and paste and save it. then say have 4 across and 2 down, you put your four all right beside each other linked where you write your sig, and then press enter and just do it another four and they SHOULD line up proporly. Good luck man!!!
LexusRules is offline
Old 10-20-02, 10:10 PM
LexusRules
LexusRules's Avatar
ok i wasn't very clear.. im assuming you have a sig, cut it into small peices, 8 for example. 4 across 2 down.. however you want. Just make sure the ones you cut are all the same height. otherwise there will be a gap
BriGuyMax
Site Suggestions & Problems
11-20-01 09:08 AM
Quick Reply: Picture - Link Question
