First airbushing attempt with a mouse...
RX 300 & 350Z Guru
Looks good future, did you us PShop?
Didn't that take a long time using the airbrush. There must be something that I am doing wrong, it would take me forever if I tried, and also would have a hard time staying within lines using airbrush. Is there a paint buckt to use to fill in large areas much quicker?
As soon as you let go off the mouse to change the size of the airbrush, if you go over any of the color spots you alread did, for example, her skin, then it makes it a different depper color, what am I doing wrong?
For each color you use or for each new part of the face put it on ANOTHER LAYER - seperate to the background layer. Now for instance If i was just coloringin her face, I'd use that peachy color and then go in and color everything in with the airbrush. Then I'd set THAT PARTICULAR layer to multiply and it would allow any deeper colors to show through, in this case the black details in her face.
It appears to me that your setting the actual airbrush to Multiply, but you shouldn't. Only set the LAYER to multiply.
If this isn't what your looking for I'll post something for you that will help, some photos of what to do. =]
future did you use a Tablet or the trusty ol mouse, I got a Wacom tablet but havent even tried it yet.I am runnig Win.XP and am having a ***** trying to get drivers for all my outboard gear, so I am hesitant about hookin it up.Are they tight though do you know? I might scan in some drawings i did and let you airbrush them if you want to practice on something
Yeah, I was setting the entire airbrush to multiple. So I go to layer and go to create new layer and then it bring up a little box and then from that box select multiple right? But can I switch it to multiple in the middle of coloring something? Attached is my go at it when I did it the wrong way.
no i used the trusty ole mouse. =]
I need a tablet bad though.
Chicago Lexus Club Moderator
This is mine
Here is my version....
