photoshop request please
Old 08-13-04, 12:11 AM
chrisgs
chrisgs's Avatar
Default photoshop request please
please change this hood to white, thanks
chrisgs is offline
Old 08-13-04, 09:34 AM
ES300SD
ES300SD's Avatar
Here is my attempt...sorry if it sucks...I havent messed around with replacing colors very much. Hope it works for you!
ES300SD is offline
Old 08-13-04, 10:31 AM
caliness
caliness's Avatar
Black isn't very friendly when it comes to changing colors.
caliness is offline
Old 08-13-04, 01:06 PM
Jc4dint
Jc4dint's Avatar
It is'nt the black that's difficult, it's the dramatic shadows that's hard. But here's my 15 mins of Photoshop time, with bigger wheels and more lowering.
Enjoy
Jc4dint is offline
Old 08-13-04, 01:10 PM
caliness
caliness's Avatar
How did you achieve the shadowing only on that portion? Did you set the layer as transparent with a white layer under it, then played with the layer shadowing effects??
Enjoy
caliness is offline
Old 08-13-04, 01:20 PM
Jc4dint
Jc4dint's Avatar
Default tips
For those who are interested in the how to
First select the section you want changed using a lasso tool, that way you don't paint or paste over parts you didn't want.
To acheive the same texture as the picture, use stamp. Use the door or other big part to copy from, then stamp in the area selected. You have to repeat as many times as desired.
For streaks use the healing tool to blend.
But now there's a huge transition from the dramatic shadow to the bright white you painted right.
Select as much of the shadow using the wand or lasso it. Then go to curves, apple M or control M for PC, adjust as necessary. But go little by little, do a step method to do the darker areas. Don't apply too much otherwise it will look funky.
Got lines and streaks or breaks from using the curve?
Use the healing tool, but beware if you go too close to the edge you pull a lot of the dark stuff you don;t need. But you can always deselect.
Oh last but not least, always, always start with a well lit, good quality picture. It will save you a lot of headaches, also doesn't hurt to work big, zoom zoom zoom.
Hope that helps some of you photoshoppers, anyone can ask me for tip if they want.
Or the other CL photoshoppers.
Jc4dint is offline
Old 08-13-04, 01:32 PM
Jc4dint
Jc4dint's Avatar
No tranparencies here, did everything in one layer with the exception of the wheels and shadow.
When you do a transparent with a layer underneath it, one you can use a textured underlayer, but you have to do some creative erasing by setting the opacity. With layer shadowing, I think you have cut a separate layer and then you can do a shadow. But I wouldn't recommend that. My newest best friend is the Healing tool, the bandaid looking one. But if you use it too much things look blurred, so moderation is key. To sum it up using the techniques you asked increases layers, which makes your file bigger. It's okay for print outs, but for web it isn't recommended. As I had struggles the first time I posted a pic on CL.
Hope that helps
Jc4dint is offline
Old 08-13-04, 11:01 PM
chrisgs
chrisgs's Avatar
thanks for all your time, Sessions kit look much better now.
chrisgs is offline
