Low end torque got worse with intake?
Old 04-22-15, 04:48 PM
Gerb
Gerb's Avatar
Default Low end torque got worse with intake?
Anyone notice that your low end torque got noticeably worse after you installed your intake? I have a JoeZ intake I remember stock being more responsive. Maybe my intake is loose?
Old 04-23-15, 05:58 PM
Gville350
Gville350's Avatar
Have you disconnected the battery ye to reset the vehicle's systems?
Old 04-23-15, 06:27 PM
merkin110
merkin110's Avatar
I have the same issue with my fsport intake. I also disconnected the battery after I installed it.
Old 04-24-15, 08:17 AM
scott1256c
scott1256c's Avatar
I could see this with some of the hot air intakes, but joe z is just an aluminium pipe, no?
Do you even have to remove the maf? That means there will be the single hose to connect, other than the pipe itself. I trust you double checked that.
I'm surprised there haven't been a few more responses, either agreeing or disagreeing with the perceived loss of torque.
Old 04-24-15, 04:22 PM
merkin110
merkin110's Avatar
Yea I don't know I like the sound but I don't like that it has less torque. Seriously considering putting back the stock intake system.
Old 04-24-15, 10:16 PM
Gerb
Gerb's Avatar
Umm, I did disconnect battery after idled 10 minutes then drove 30 minutes. Also my JoeZ intake is like Matte Black finish did I buy a fake one?
http://my.is/forums/attachments/f155...shot-019aa.jpg It's that
Old 04-25-15, 07:33 AM
mmaandy
mmaandy's Avatar
No Matte black doesn't mean fake. There are a variety of Joe Z Intake colors including that one.
Old 04-25-15, 08:24 AM
tomiv9
tomiv9's Avatar
My limited understanding of after market intakes and exhausts is that they add a few HP when ur at high RPMs. Generally nothing u can feel. They are for looks and sound. I have heard they sometimes decrease HP/torque at low RPMs but not sure if that's true with fsport/Joe z tube
Old 04-25-15, 10:42 AM
merkin110
merkin110's Avatar
I'm going to reinstall mine just to verify that all of the hoses and the tubes are all installed properly.
Old 04-29-15, 02:27 AM
Gerb
Gerb's Avatar
let me know how ti goes. Maybe I just don't drive hard enough lol
Old 04-30-15, 05:08 PM
WillK
WillK's Avatar
Intakes can rob low end as they're designed for peak HP which occurs up top.
I've always followed the rule of intake AND exhaust at same time to keep from losing torque down low.
Like other's said, you could try to reset the computer. Or you could drive it like you stole it from a stop a few times and the computer should adjust.
I haven't done anything to my IS yet so not sure how it'll respond but it might be time to start tinkering with stuff.
Report back if the ECU reset works.
Old 04-30-15, 05:16 PM
merkin110
merkin110's Avatar
I did the ECU reset already maybe I need to do it again?
Old 05-01-15, 07:59 AM
JV6
JV6's Avatar
I noticed my gas pedal was a lot lighter when I installed my F sport intake tube only. Before I installed the tube I disconnected the battery, I believe it was disconnected for a good hour aswell. Mileage and everything still the same, didn't care for the sound so I left the lower box stock.
Old 09-21-15, 07:21 AM
Alphaman19
Alphaman19's Avatar
My SRT intake seems to suffer from low end grunt as well.
Granted, it begins to come alive around +4k rpm (and it sounds like an old fashioned 4 barrel carb), and when it does I gotta make sure I have plenty of room ahead of me.
But I don't live in that rpm range much and while the added torque is nice, I'm not sure if it's worth the price of all the extra noise.
Maybe I'm just getting old.
Old 09-23-15, 09:14 PM
MWIS350
MWIS350's Avatar
I think the intake pipe might heat soak which decrease HP. I have Afe stage 2 intake with plastic tube, and so far so good.
Quick Reply: Low end torque got worse with intake?
