H-Pipe Question for 3IS Exhaust
Old 11-23-14, 07:39 PM
Fingers007
Fingers007's Avatar
Default H-Pipe Question for 3IS Exhaust
Members,
I'm considering removing my resonators and replacing them with an X-pipe and straight pipes back to the mufflers. However, I saw this picture from ultran00b and I'm wondering if that section between the resonators and the convertors is some sort of H-pipe. Thanks for the help.
Old 11-24-14, 06:56 PM
Loe
Loe's Avatar
it's a crossover chamber that's neither and X-pipe nor an H-pipe.
Old 11-24-14, 10:58 PM
Fingers007
Fingers007's Avatar
What does it do? Intuitively, it seems like an X-pipe. If so, is it worth replacing with an actual X-pipe? Thanks.
Old 11-25-14, 08:00 AM
Loe
Loe's Avatar
equalize pressure from both sides. it acts as a pseudo H-pipe in a sense that the two chambers are never forced to mix together like an X-pipe. Its also very thin, so I would consider it a bottleneck and would replace with a traditional X-pipe.
Old 11-25-14, 10:56 AM
Fingers007
Fingers007's Avatar
Thanks for the insight Loe. I'll get that X-pipe and post some pictures later. I'm planning on getting the magnaflow X-pipe crossover but I'm still researching if I should get get the 2.25 inch or the 2.5 inch.
Old 11-26-14, 11:25 PM
F350
F350's Avatar
you could go with a bolt-on mid pipe as well
Invidia
Old 11-27-14, 09:01 AM
Fingers007
Fingers007's Avatar
Invidia
Thanks, I'm certainly considering the invidia midpipe. If there's a black Friday sale, I'll definitely pull the trigger.
Old 11-28-14, 04:03 AM
Loe
Loe's Avatar
Go on ebay and bid, I got mine for $515 shipped, fitment and quality is wonderful, and the Invidia is approx. 28lbs lighter than the OEM midpipe. An exhaust shop will do an X-pipe/resonator delete for $200-$300, but at least with the Invidia you'll delete the secondary cats (which are approx. 500-600 cell units).
I have it, the exhaust note sounds a little louder inside, no drone, but outside sounds very nice and noticable, especially in the higher RPM ranges, like a factory "sport" exhaust option (though sounds different than the actual F-sport exhaust in that it's higher in pitch) Best of all, the car no longer feels bottlenecked in the higher rev ranges, more responsive, and more eager to rev, and more low/mid-range power.
Old 11-28-14, 04:14 AM
Loe
Loe's Avatar
https://www.clublexus.com/forums/is-...on-my-3is.html for a sample clip of a midpipe on stock axle back. Its on a 2nd gen but sounds similar on a 3rd gen.
also, cold starts gives off a nice bassy bark without being obnoxious.
Old 12-14-14, 05:47 AM
Fingers007
Fingers007's Avatar
Thanks for all the insight guys. I went with the invidia mid pipe. I purchased on black Friday and I installed it myself. I had to have a muffler shop loosen the o2 sensor for me but everything else went well. It sounds very mean. Now I just need to find the Infiniti douche in my neighborhood and blow his doors clean off.
Old 12-23-14, 09:15 PM
Heard006
Heard006's Avatar
Does your check engine light come on with the midpipe?
Old 12-24-14, 03:29 AM
Loe
Loe's Avatar
no CEL since the midpipes cats are not monitored by O2 sensors
Old 12-24-14, 06:46 AM
Fingers007
Fingers007's Avatar
Concur, no CEL. Just lots of awesomeness. My car is actually more fun to drive now.
Old 12-26-14, 04:41 PM
nycsoer
nycsoer's Avatar
does this fit on the awd model???
Old 12-27-14, 10:00 AM
Fingers007
Fingers007's Avatar
Probably not
talbott
10-14-13 04:56 PM
superpower
Performance & Maintenance
04-17-12 11:09 PM
CrimsonSC3
15
07-04-11 12:35 PM
1uzfelbc
09-28-07 11:12 PM
Quick Reply: H-Pipe Question for 3IS Exhaust
