Axle Back Removal Ins
Old 09-07-14, 09:20 AM
dairon
dairon's Avatar
Post Axle Back Removal Ins
Hello guys I wanted to remove my axle back exhaust and when i got under the car, I found out that one of the screws was really hard to take off, in fact i could not get my hand on it and take it off, do you need any special wrench or anything or do I just need to get under again with more patient.
Old 09-07-14, 09:49 AM
Dark9t316
Dark9t316's Avatar
Try using a torque wrench or impact wrench.
Old 09-07-14, 03:17 PM
afdavey
afdavey's Avatar
Why would he use / you suggest a torque wrench for bolt removal...
Depending on the age/ condition of the bolts (there are 4) use a penetrating type spray on the bolts, let them sit for a bit. Then use a box wrench (safer than an open end to prevent slip) or a 3/8" ratchet with a 'long' handle for some leverage. If I recall the top bolts don't have much room for taking a big swing in loosing. I actually probably used a flexible head wrench / ratchet. Nice and easy. steady pressure will get them moving.
Old 09-07-14, 09:04 PM
Dark9t316
Dark9t316's Avatar
Okay maybe not the best idea off the bat. Try soaking in WD40 over night.
Old 09-08-14, 01:24 AM
Larry96815
Larry96815's Avatar
Try a universal joint with a socket and a loooonnnnggg handle. Worked for me.......
Bullochdaw
07-18-18 04:54 PM
whooper20
Performance & Maintenance
08-21-11 09:31 AM
e-man
07-22-06 11:22 AM
PES300
09-09-05 09:21 PM
Jasoneo5
10-29-03 08:35 PM
Quick Reply: Axle Back Removal Ins
