Official 3IS 1/4 Mile Thread
Old 07-24-14, 06:13 AM
L0ngJ0hn
L0ngJ0hn's Avatar
Default Official 3IS 1/4 Mile Thread
Post your 3IS 1/4 mile times.
Include all the info you have such as mods, weight reduction, track info etc..
250's and 350's all welcome.
Times with slip will be added to the list
-Long_John: 2014 IS350, Mods: Stock 14.01@101mph
Old 07-24-14, 06:26 AM
L0ngJ0hn
L0ngJ0hn's Avatar
First time at the track with the new car. Its a 2014 IS350 Fsport RWD 8spd.
Stock, Full weight, tire pressure at 38psi.
Runs were done in manual mode using paddle shifters and Sport+
I think 13's are possible as she sits.
Videos to follow
Old 07-29-14, 05:55 PM
SRQwelder
SRQwelder's Avatar
I'm going Thursday night to the local strip. I'll post results Friday.
Old 08-08-14, 10:48 PM
L0ngJ0hn
L0ngJ0hn's Avatar
Did you end up going?
Almost forgot.. Here's the videos
Old 08-10-14, 04:35 AM
itBurnsISF
itBurnsISF's Avatar
Your videos make me totally wish I got the 350 over the slug 250.
Old 08-10-14, 07:38 AM
mello03
mello03's Avatar
That's pretty darn good. I think you could definitely get into the 13's with some better tires and a better 60ft. Shifts were right on IMO as this thing makes peak power at 6400. I don't know about you, but I think this car isn't much on the low end but impresses me with its top end roll power for what it is.
Old 08-10-14, 10:32 AM
Larry96815
Larry96815's Avatar
I remember reading some place that in Sports modes and at WOT the transmission shifted at redline. Have you tried using Sport mode but not shifting manually? That would do away with any error in manual shifting. Just a thought.
Aloha,
Larry
Old 08-10-14, 12:25 PM
mello03
mello03's Avatar
Long John, I see where traction control was off. Did you hold the button down to turn it almost all the way off or just push it once. Apparently the "pedal dance" works on the 2014s and turns it all the way off. I haven't done it yet but apparently the trac really holds this car back.
Old 08-10-14, 01:19 PM
Dustondo
Dustondo's Avatar
is it not completely off once that yellow light comes on after holding it for five seconds?
Old 08-10-14, 02:36 PM
mello03
mello03's Avatar
I'm not sure, but I've read that it's not ALL the way off until you do this sequence with the pedals. I've heard it takes it almost all the way off. Maybe someone who knows will chime in.
Old 08-10-14, 08:38 PM
L0ngJ0hn
L0ngJ0hn's Avatar
I held the button down for a couple seconds and it was completely off. I was able to do a small spin of the tires and If you listen carefully, I just touched the limiter on the second video going from 1st to 2nd gear. I've also been able to spin/drift/slide the car this way without any interruptions.
When I just press the Trac button. The light comes on but then goes away after a certain speed.
Also.. It'll only go into full off when I'm at a complete stop.
I did a couple runs in sport+ mode and was getting 14.5's constantly. It shifts earlier.
In this run I accidentally reacted and pressed the shift+ paddle on the 1-2 shift. You'll see it shows D then flips to 3 and back to D. It completely ignored my request and went through the gears as normal instead of skipping 2nd and going to 3rd. Note where it shifts in Sport +
Old 08-10-14, 11:32 PM
Larry96815
Larry96815's Avatar
At what rpm did you actually shift the paddle? I am curious of the lag time from paddle shift until transmission actually shifts.
Old 08-11-14, 08:25 AM
jkonquer
jkonquer's Avatar
anyone know what's the fuel cut rpm on is350?
Old 08-13-14, 01:49 PM
sdotk
sdotk's Avatar
lol same here...damn
Old 08-13-14, 07:42 PM
nayuta
nayuta's Avatar
nice run there
Quick Reply: Official 3IS 1/4 Mile Thread
