ECU question
Old 06-30-14, 05:43 PM
Larry96815
Larry96815's Avatar
Default ECU question
If I disconnect battery will I lose all of my presets?
Old 07-09-14, 06:46 AM
sloosh
sloosh's Avatar
What presets on the ECU are you talking about? I don't think you know what an ECU is based on your question....are you talking about the settings in your Nav system?
Old 07-09-14, 07:05 AM
L0ngJ0hn
L0ngJ0hn's Avatar
You will most probably lose your settings on the stereo/nav. The ecu controls the engine and should also reset but you wont notice anything different there.
Old 07-09-14, 10:17 AM
Larry96815
Larry96815's Avatar
Radio stations, Nav system, Bluetooth, everything that I have changed since the day I bought the car.
How about just taking out the two (I believe) ECU fuses instead of disconnecting the battery?
Mahalo,
Larry
Old 07-09-14, 11:19 AM
drbazing
drbazing's Avatar
I believe when you are disconnecting the battery (power), you are doing a hard reset. Most likely, the electronics in the car will go back to it's initial setup.
Old 07-30-14, 09:00 AM
JB5674
JB5674's Avatar
ALL -
Surprisingly enough, you DONT lose a thing. I installed my intake and had the battery ( neg terminal ) off for about 15-30 mins. I got back in the car, everything was the same. The first time you turn the car over, it shuts off immediately. Then a "loading" screeen comes on, then you just crank over as you would. Hope this helps.
Old 07-30-14, 11:47 AM
Dark9t316
Dark9t316's Avatar
I did not lose a thing. My AC was turned off.
Old 07-30-14, 11:23 PM
specONE
specONE's Avatar
yeah the stereo is pretty smart. it doesnt seem to lose settings when battery is disconnected.
its probably saving the information to data disk space to remember even with battery disconnect unlike older vehicles.
lserlohn
RX - 1st Gen (1999-2003)
06-09-11 06:11 AM
joonsta
06-24-07 04:37 PM
Pianoman72
GS - 1st Gen (1993-1997)
17
12-19-03 06:09 PM
anthracitetarga
SC- 1st Gen (1992-2000)
31
03-21-03 03:15 PM
Quick Reply: ECU question
