Lexus IS F paddle shifters
Old 01-26-14, 08:42 AM
Compthis
Compthis's Avatar
Default Lexus IS F paddle shifters
Is anyone aware of a steering wheel where the paddles are attached to the wheel rather the steering column? I would prefer the paddles move as I turn the car rather than stay still.
Does anyone know why lexus would build the wheel and paddles the way they did?
Big brain fart alert: I meant to say the total opposite in my post. Sorry, I'd prefer if the paddles didnt rotate with the wheel.
(I have no idea how this post ended up here, I was in the isf forum when I opened up a new post)
Old 01-26-14, 07:57 PM
accelerate
accelerate's Avatar
What yours aren't attached to your steering wheel?
Old 01-26-14, 08:43 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The paddles are attached to the steering wheel and do turn with the steering wheel. I don't know what you're talking about.
Jeff
Old 01-26-14, 09:39 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,844 Likes on 2,332 Posts
Jeff
I also have no clue what compthis is saying. I've had an IS-F for more than 5 years now and what you (the OP) are saying makes zero sense. The shifters rotate with the wheel, and always have on any 2IS.
Old 01-27-14, 12:14 AM
Snyperifle
Snyperifle's Avatar
Compthis, my IS250 has its paddles attached to the steering wheel. I'm willing to trade it for your IS-F with its paddles attached to the column.
xD
Old 01-27-14, 05:15 AM
Compthis
Compthis's Avatar
Old 01-27-14, 07:03 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
You could do that, they're only switches, but it would take a bit of fabrication and it would be expensive to have it look factory-ish.
Old 01-27-14, 06:52 PM
NYKnick101
NYKnick101's Avatar
there are aftermarket kits that support that but it requires an aftermarket HUB assembly which i dont think an OEM wheel can bolt to so you would have to use an aftermarket steering wheel. Is it worth it? If you are on the track frequently then it May be worth it because its hard to upshift coming out of a hard turn/down shift into a turn. Having stationary paddle shifters is very convenient. It wont change transmission shift time though which is where it MAY NOT be worth it
\\http://www.jegs.com/i/Performance+Au...FZBj7AodEUQA3Q
Old 09-15-14, 11:22 AM
allst4risf
allst4risf's Avatar
,1 sec shift per lexus brochure. bmw dct is milliseconds.
Old 06-15-16, 08:07 PM
bran4f33r
bran4f33r's Avatar
Hey do you know if these are a direct plug in to a 06 is350 steering wheel
Old 06-15-16, 09:20 PM
iinkz
iinkz's Avatar
Yes. Direct Plug and play
Old 06-16-16, 07:33 AM
newgsman
newgsman's Avatar
I sometimes just bump the gear shifter if the paddle shifter is in an awkward position during a turn.
Old 06-16-16, 09:28 AM
mindcrime
mindcrime's Avatar
that's why I use the shifter from 1st to 2nd when I'm turning.
Old 06-16-16, 03:59 PM
2URGSE
2URGSE's Avatar
Just use the shifter to go through gears when you go through a turn....
Old 06-17-16, 10:35 AM
bbong
bbong's Avatar
I never had a problem shifting with paddle shifters when turning, just have to get used to it, see how Rally pros are doing it and do the same.
Quick Reply: Lexus IS F paddle shifters
