LSD from a Scion FRS into IS250 RWD automatic
Old 03-28-14, 01:35 PM
  #76
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
That's a Supra clutch LSD, not an IS300 LSD.
Jeff
Old 03-28-14, 06:10 PM
  #77
Gville350
Gville350's Avatar
^Oops, didn't read the entire listing there. LOL!
Will that thing work in an IS250 though? If not the housing, will the LSD in the 250 diff?
Old 03-28-14, 10:27 PM
  #78
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
The LSD will fit in an IS250 housing. The Supra housing won't fit the IS250.
Jeff
Old 04-05-14, 09:24 AM
  #79
DarthLex
DarthLex's Avatar
Ok so my question is are you using the FRS/BRZ pumpkin or just the LSD? Would that matter at all. Also the ones who have add the LSD do you have any other suspension mods?
Old 04-05-14, 11:36 AM
  #80
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
You can use the entire assembly or just the LSD, either way would work fine.
Swapping the entire thing gives you 4.10:1 gearing.
Jeff
Old 04-05-14, 06:16 PM
  #81
DarthLex
DarthLex's Avatar
Jeff
Thanks for the info will have to see if I can find something in Texas.
Old 07-28-14, 07:46 AM
  #82
Shanksmoon
Shanksmoon's Avatar
I would assume that the rear Diff pumpkin from an FRS MT. Will also fit in a is250 MT
Can someone confirm I am about to make a purchase.
Thank you
Old 07-28-14, 08:20 AM
  #83
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Yes.
Jeff
Old 07-28-14, 08:34 AM
  #84
Shanksmoon
Shanksmoon's Avatar
Thanks Jeff,
I appreciate the super quick reply. I will let you guys know how the upgrade goes. I am going to try out the 4.10 gear ratio for a while but I will keep my old diff if I want to go back to 3.9
Cheers,
Eric
Old 07-28-14, 10:30 AM
  #85
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
If you have an MT, your original diff would have been 3.73, only the AT uses 3.91.
Jeff
Old 08-03-14, 11:38 AM
  #86
JETLEX
JETLEX's Avatar
Finished swapping in a 2013 BRZ rear differential into my 2007 IS250 this weekend - axles slide in just fine.
I pulled the diff cover, inspected & cleaned everything, then filled it with Motul Gear 300 75w90 once in place.
Pulling the axles is easy with an SST type tool as shown in the repair manual - it is OTC tool # 6541 / 519375 - can be used with regular slide hammer.
Thank you to Mike @FIGS, as well as Jeff Lange for all their help!
Haven't had a chance to drive it too much yet, but so far my impressions are that it is a little more planted in the corners.
Attached Thumbnails LSD from a Scion FRS into IS250 RWD automatic-20140420_132229-copy.jpg   LSD from a Scion FRS into IS250 RWD automatic-20140720_174120-copy.jpg   LSD from a Scion FRS into IS250 RWD automatic-20140703_174543-copy.jpg
Yodog (10-19-21)
Old 08-03-14, 02:30 PM
  #87
Shanksmoon
Shanksmoon's Avatar
Jeff
Ahhh. The post on page one confused me. Got the complete unit last week. Can't wait to install it! Came with 9000km (~5400 miles).
Old 08-05-14, 12:35 PM
  #88
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
Yeah, I changed mine from 3.73 to 3.91, so that's why I have 3.91, haha.
Jeff
Old 08-05-14, 12:36 PM
  #89
Gville350
Gville350's Avatar
Enjoy the new toy!
Old 08-06-14, 09:00 AM
  #90
Smashin
Smashin's Avatar
Nice!!!
I have a KAAZ LSD I am waiting to see if it'll work on my IS350... Just need to find some time on a weekend to do it.
Quick Reply: LSD from a Scion FRS into IS250 RWD automatic
