Custom Magnaflow Axle-Back Exhaust
Old 10-07-13, 04:36 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Originally Posted by Stitch626
Sounds great!
Originally Posted by dangla1603
Thanks for the compliments. For the money, tough to beat Magnaflow. Here's another pic while it was at the exhaust place right after all the welds. The entire system was made as a bolt-on from the resonators back (axle-back) so I can always swap back the stock exhaust very easily by undoing the two bolts at each plate junction.
Old 10-08-13, 06:57 AM
carderoni
carderoni's Avatar
Looks good! You stated it's 2 1/4 inch piping - is that any larger than the stock piping?
Old 10-08-13, 06:16 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Thanks.
It sure is. Stock is fairly restrictive at 1.75". All done to slow down and muffle this sweet sounding engine's output.
Old 10-08-13, 07:04 PM
Stitch626
Stitch626's Avatar
do you think that by simply installing bigger piping to the stock exhaust would give it a better sound and if so does welding need to be done?
Old 10-08-13, 07:48 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Nah, won't make a noticeable difference in sound since the bottleneck is still the stock mufflers. The cheapest way to get sound is remove the stock resonators and replace with welded straight pipe. However, expect a raspy less refined exhaust note. The next cheapest is weld on two magnaflow mufflers like mine to the stock pipes.
Old 10-11-13, 06:49 AM
Stitch626
Stitch626's Avatar
I'm getting pricing on the new magnaflow system released for the 2014's soo excited!!
Old 10-11-13, 04:53 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Sweet! Post the details when you get them.
Old 10-11-13, 11:03 PM
xbigboix83
xbigboix83's Avatar
Has anyone bought the magnaflow catback?
If anyone has bought this catback. Can you let me know how good it sounds and if you get better performance. Thanks
Old 10-12-13, 05:05 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Attachment 301078
This has just been released and is is nearly identical to mine so it will sound extremely close. Even the tips are the same. Note, like mine, this is an axel-back which is from behind the resonators. (They often mis-label catback and axel back). On a 350 expect a slightly deeper, sound. For instance check this video out below. Sounds great and if you can compare mine and this next one, the only difference is the resonators are removed which makes it louder and adds some rasp/metallic noise on mid-to-high throttle input. In addition to this, be careful with a resonator-delete setup since you will get some annoying drone at constant city and highway speeds.
As for power, yes, I feel it breathing better and a little quicker overall. I did notice a touch less torque on takeoff (as my exhaust specialist had told me to expect that the idle torque will be 1-2 ft-lb less), but makes up for it after 1500 rpm. Even hitting near redline feels peppier as opposed to feeling it was dying out a little before. No dyno testing, but on the 250, my exhaust builder said to expect a real-world increase of between 6-8 hp more on my 250 with another similar gains in torque from ~1500 rpm onwards to redline. Extrapolate this on a 350, expect 10 hp/10 ft-lb torque easily.
My favorite sounding, but not by much, is the JoeZ and the F-Sport (2IS). However, because of the higher cost (based on the 2IS), with similar quality stainless steel construction, the Magnaflow is tough to beat... and really?? for under $500 on Ebay, WOW since others are now selling this for 800-900$. No brainer for me to buy this and on Ebay. Good luck and keep us posted.
Old 10-12-13, 06:13 AM
xbigboix83
xbigboix83's Avatar
Wow great explanation of it. Thanks !! Will keep you posted if I do get it. Maybe something will come out better !!
Old 10-12-13, 09:19 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
^^^ I took a video of the car under normal acceleration and sounds great! See my Build thread:
https://www.clublexus.com/forums/is-...-thread-8.html
Old 10-12-13, 10:22 AM
Stitch626
Stitch626's Avatar
^^^ I took a video of the car under normal acceleration and sounds great! See my Build thread: https://www.clublexus.com/forums/is-...-thread-8.html
Sounds good to me
Old 09-28-14, 05:34 PM
mnm27mnm
mnm27mnm's Avatar
Attachment 301078
I know this is old but can't believe the kit was is the $400s. Did you buy it.? Everything on eBay is over $800.
Ii did a custom Magnaflow axle back for $500
Old 10-29-14, 10:19 AM
fryer
fryer's Avatar
Pretty much spot on to how mine sounds. I love it!
Nice video!
05ls430518
03-15-18 02:44 AM
djrazr
SC- 1st Gen (1992-2000)
26
06-13-10 03:33 AM
farbyndrn
IS F (2008-2014)
03-17-10 02:01 PM
nick01
IS F (2008-2014)
05-19-08 09:45 AM
craigt
GX - 1st Gen (2004-2009)
12-02-03 11:29 AM
Quick Reply: Custom Magnaflow Axle-Back Exhaust
