Polished Trans Cooler
Old 01-13-03, 03:21 PM
Pearlpower
Pearlpower's Avatar
Default questions
The holes are not cut into the lower engine shroud. They are cut into the plastic that is beneath/in front of the radiator. It is sort of a dust cover though it does not appear to serve any purpose. So you can take this car and run the front end into the street as hard and long as you would want and the lines would never be touched. You would destroy the entire front end before the lines are even touched. Plus, these are steel lines in this area , not the rubber ones.
Best of luck on your install
Lee
Old 01-13-03, 09:28 PM
Received 2,126 Likes on 1,378 Posts
Default Re: Nice
Originally posted by Pearlpower
Paul
Check your email for the good news
Lee
Very cool. I'm jacked.
Old 10-06-08, 01:44 PM
sam430
sam430's Avatar
Originally Posted by Ag02M5
What is the cost/model #?
Thnx.
Ryan
Second that. Also would like to see a pic of the routing lines...don't know which one is the return line. It should be Return line from factory radiator cooler -> custom cooler ->back to the return line that was disconnected from the factory radiator... correct?
Old 12-02-08, 09:09 PM
Deception
Deception's Avatar
question. i already ordered the bm cooler. so i want to get this straight before i install it. now am i still using the stock trans cooler on the car, or do i just take the hose out and put it into the new cooler??
Old 12-02-08, 10:23 PM
sam430
sam430's Avatar
keep it in series. You can install it before or after the stock cooler. I installed mine after it's cooled from the stock ...then flows into my bmp cooler and back into the transmission.
I wouldn't trust the bm cooler by itself.
Old 12-02-08, 10:38 PM
Deception
Deception's Avatar
cool thanks, im just preping for the na-t build. =D
Old 01-22-09, 11:54 AM
Euro09
Euro09's Avatar
Do u have any pix that showing how to connect from where to where ?? Im lost . I saw some pix above but still dont know where to start that steel line and end up to where?
Old 01-22-09, 12:55 PM
sam430
sam430's Avatar
http://bananags.grantham-internation...ler/index.html
the curved one is the return line (after it cools by the stock system). I'd detach that and hook it up to you cooler and complete the circuit. The straight one is from the tranny to the oem system. Don't bypass the oem system...
you can install pre or post.
Old 01-22-09, 07:00 PM
Euro09
Euro09's Avatar
hey take a look at the pix (link) tell me where did I find that hose#1 and the hose#2 that I blue mark in the pix. I appreciated man.
http://i230.photobucket.com/albums/ee160/tienxoxo/1.jpg
Old 01-22-09, 07:32 PM
sam430
sam430's Avatar
It doesn't really matter. Just unhook the curved line and complete the circuit. It doesn't matter if it flows from 1 to 2 and back into the transmission or from 2 to 1 and back into the transmission. You just care about intercepting the flow.
The two hose comes with the kit. You have to buy another one from an auto store because you don't wanna cut the one supplied (too short if cut).
Old 01-22-09, 07:52 PM
Euro09
Euro09's Avatar
so that means I have to unhook the two hoses from my Radiator ? correct??
Old 01-22-09, 08:17 PM
sam430
sam430's Avatar
You just unhook one... then connect it to your cooler...then from the cooler, it goes back into the transmission.
Old 01-22-09, 08:19 PM
Euro09
Euro09's Avatar
imagine this is a complete line. ----
then you disconect it: -- --
then you connect the cooler like so
cooler here. hope that comes out right.
after the sytem or b4 the OEM sytem ??? I think its better if u connect after the OEM system right??
Check this out, somethihg like this lol
http://i230.photobucket.com/albums/e...ntallation.jpg
Old 01-22-09, 08:27 PM
sam430
sam430's Avatar
I'd do the after. I don't think it'll affect the system much... but some people thinks it could be over cooled. LOL...i highly doubt it.
You can do the other line if you want...the oem radiator will keep it warm before it circulate back.
Old 01-22-09, 08:42 PM
Euro09
Euro09's Avatar
so should I stick with that diagram(the one I draw) ??? Is that how u intall it in your car???
Quick Reply: Polished Trans Cooler
