IS350 Revision S/C
Old 06-03-12, 05:12 PM
  #61
iSuxeL
iSuxeL's Avatar
You were running a C1 unit?
Old 06-04-12, 08:13 AM
  #62
mikellucci
mikellucci's Avatar
Yes because I rebuilt the C1 with ceramic $$$ bearings on the impeller shaft. The compressor is actually a bit smaller on the C1 vs C2. Needless to say the C1 is in a garbage bag in the corner of my garage after what happened to it a few weeks back. lol
Might as well be glass packed into these!
Old 06-04-12, 10:16 AM
  #63
gompka
gompka's Avatar
Interesting story, it seems like a lot of superchargers have bearing problems. I had a supercharged scion tc at one point and the bearings were always failing on the shaft side of the unit. I came to the same conclusion as you though, i don't recommend ceramic bearings in the s/c. I just tell people to change out the standard bearings after x amount of time. Good luck with the build though, i didn't realize the stock ecu can compensate for that much boost.
Old 06-04-12, 10:29 AM
  #64
mikellucci
mikellucci's Avatar
Thanks for chiming in!
Those are my conclusions at this point as well - Deal with an easy rebuild after XXk miles using ABEC-7 bearings and not ceramic.
Did you use a "Procharger" unit on your Scion? I would think this same logic applies to many bearing / gear driven S/C's. I have no idea how people run over 15 psi on some superchargers and dont have to rebuild their units until 20k miles down the road..
I've been looking at Raptor and Rotrex S/Cs more recently...I'm still not convinced they are that much better over the long haul.
Old 06-04-12, 10:36 AM
  #65
gompka
gompka's Avatar
The trd supercharger uses a vortech v2 unit i believe, surprisingly most people don't have issue with the supercharger itself, just with the pulley side. The inside of the vortech unit looks similar to your procharger though, its the same setup with 2 impeller bearings.
Old 06-04-12, 10:58 AM
  #66
mikellucci
mikellucci's Avatar
Beefy gears that look like they have no choice but to spin; I like that!!
Do you know how valuable those wave washers are sitting on top of the bearings (mount into casing)? I've read mixed opinions on their purpose and how necessary they truly are.
The difference with the C1/C2 impeller shaft (aside from being fragile) is it uses that giant 6009 bearing as well for a total of 3... A bearing inside of a flange inside of a bearing then of course the bearing on the end of the shaft. That makes me say WTF
The pulley shaft on the other hand is very straight forward and stout. From a novice perspective I can see why the pulley side never fails...the impeller side always goes first! lol
Old 06-05-12, 12:10 PM
  #67
mikellucci
mikellucci's Avatar
Just thought I'd share...learned the true importance of wave springs.
Wave Springs eliminate play and minimize bearing noise. The constant light/medium pressure they apply removes play between the ball bearings and the bearings’ inner and outer races. Preloading can reduce the possibility of bearing damage due to vibration (vibratory loading) and wear due to repetitive and non-repetitive runout.
Old 06-05-12, 01:46 PM
  #68
Gville350
Gville350's Avatar
^Interesting. Reminds me of when I had to shim my Honda trans for a Quaife LSD and I bought like 4 different shims to set the exact pre-load I wanted. After time though I would figure that wave spring would start to increase the amount of play/preload and cause problems.
Old 06-06-12, 05:13 AM
  #69
mikellucci
mikellucci's Avatar
Yes, I agree.. These little things could quite possibly be the root of many issues over time with the Procharger units. Depending on what bearings are used and the environment or elements of each application... Damn it! lol I'm going to call ATI and see what they say; best Tech. Support ever, its like the guys are bored and just want to talk to anyone that calls.
Old 06-06-12, 04:50 PM
  #70
iSuxeL
iSuxeL's Avatar
I still can't understand what happened but I ran my car HARD and I have numerous people to vouch and never had a problem. And just a little tidbit, upgrade your intercooler
Old 06-06-12, 05:12 PM
  #71
mikellucci
mikellucci's Avatar
You didn't upgrade to ceramic bearings, right? What bov did you run? I was stupid and tightened the adjustment screw too tight on my Synapse to fix my low boost surge at the cost of surging the **** out of everything at 5.5psi for about 10 days.
Look closer, my fmic is a treadstone, larger then the LMS and efficient as all hell.
Old 06-13-12, 09:38 AM
  #72
mikellucci
mikellucci's Avatar
Havent been driving my car much and traveling a lot with work. I've been thinking more about vacuum source and the performace of the blow off valve with the changes I made over the last month or so. I still do not like the flutter I'm hearing at 0-2psi even though above that blows off cleanly.
Dug up some old info. and view points of members past including a post from Synapse. First things first I think I'm going to drill and tap a new spot on the intake manifold to pull pressure from for the BOV.
I'm T'd here for bov only right now.
Where as Elias (pepos) tapped his own-
Here is a picture of the Vacuum for the Synapse.
I also removed from the inside of BOV the small preload spring and attached to Vacuum source both ports A & B.
Now the BOV works like a charm.
Stays open at idle and light throttle closes when it senses boost and opens again when i step off without fluttering or surge.
Taking VAC/Boost from the already existing port that the manifold has didn't work well.
Perhaps it's not free and it restricts the signal somehow.
I'm only using that right now to feed the PLX Boost and AFR device.
Synapse provided some insight years ago with the following-
Hey boys, I'm glad that you're seeing first hand the benefits of the Synchronic design on your SC system. I watched the videos and have a couple of tips that will make the BOV work, about 100% better for your application.
Please connect the 3rd port (Port C) to a boost-only source. Do not, use a check valve to a vacuum source as it will trap pressure. Try to gett boost-only from one of the charge pipes, or perhaps a threaded fitting on the compressor housing.
Once you have boost-only connected, play around with different hose combinations of the vac hoses on the back. You have 3 possible combinations, both hoses, and 2 with only either hose on the back connected.
Give these things a try and you should see some marked improvements.
These are improvement areas for me that I hope to achieve in the near future.
Old 06-13-12, 09:48 AM
  #73
heyarms
heyarms's Avatar
Hmm looks like you found some good info!
On a side note, I'll be receiving the LMS kit from you today, says FedEx. And i opted for my shop to install it... So it'll be getting installed tomorrow and Friday. I may direct their attention to this thread and others for any background and troubleshooting haha. :
Old 06-13-12, 09:56 AM
  #74
mikellucci
mikellucci's Avatar
Hey bro, thats good news! I'd like to see you DIY as I can be of any help you might need and save you some $. I completely understand the convienance factor with the shop though. I would likely advise them or get their input around adding a better port on the intake manifold for pressure though. I think I'm going to tap one similar to Elias above!
Just tell em to look at my pics, I gave you the same spacers I had machined for the studs and the 2 tensioner pulleys. Its all together on the bracket but they'll have to undo it when installing of course. Take pics!
Old 06-13-12, 10:08 AM
  #75
gompka
gompka's Avatar
Are you tee'd inline with the evap clicky valve? They had the same setup in my scion tc with the trd supercharger and I changed it over to a much bigger and more isolated vacuum source also. I thought my bov became slightly more responsive after that change over, but might have just been in my head, i had an hks ssqv.
Quick Reply: IS350 Revision S/C
