GS430 Better Tranny shifts just by adjusting dial? - Page 2 - Club Lexus Forums
Thread Tools Search this Thread
Old 10-06-11, 11:33 AM   #16
sakataj
sakataj's Avatar
Quote:
Originally Posted by denut-L View Post
Taking my tranny pan off as we speak. Can't wait to rerace my buddy's M3 again. This time I should pull him further before my speed cut off kicks in
post a actual pic please instead of the drawing
sakataj is offline   Reply With Quote
Old 10-06-11, 04:52 PM   #17
GammaLex
GammaLex's Avatar
Quote:
Originally Posted by vwynn View Post
wait theres multiple sleeves. how come you only adjust just one vs maybe adjust the others as well?
You only adjust the main one increasing pressure across the line
GammaLex is offline   Reply With Quote
Old 10-06-11, 08:47 PM   #18
sam430
sam430's Avatar
Quote:
Originally Posted by irokdastar View Post
i did my trans flush and here is a pic of the switch.the picture is after i turned it. what you do is use a flat head and push it in then turn to the right. btw keep an eye on the metal tab as it will come out when you turn it. this actually worked very well and it uses less gas go figure.
I bought the tranny gasket a few years ago....grrr...where is it now lol
sam430 is offline   Reply With Quote
Old 10-06-11, 10:31 PM   #19
GS4_Fiend
GS4_Fiend's Avatar
how much do you turn it ?
GS4_Fiend is offline   Reply With Quote
Old 10-06-11, 10:44 PM   #20
sam430
sam430's Avatar
push in, turn twice clockwise. Do you see the three grove held by the metal tab? That's it.
Old 10-07-11, 09:37 AM   #21
vwynn
2 full revs? or just 2 clicks?
vwynn is offline   Reply With Quote
Old 10-07-11, 11:08 AM   #22
sam430
sam430's Avatar
That's. A good question, I'm wondering if it will tighten more with a full rev or it'll just reset.
I would only do two clicks.
Old 10-07-11, 12:02 PM   #23
vwynn
someone should be a guinea pig
Old 10-07-11, 12:51 PM   #24
Rock-a-Lex
Rock-a-Lex's Avatar
If my ride wasnt my dd, i'd try it first.
Rock-a-Lex is offline   Reply With Quote
Old 10-07-11, 01:00 PM   #25
vwynn
even better man . this way u will feel the difference every single day haha. my next maintenance thing will be changing out the seal n replacing it with a gasket.. while im in there i might as well turn the thing
Old 10-07-11, 03:59 PM   #26
GammaLex
GammaLex's Avatar
2`clicks its that easy like it had 3 settings from the factory.
Old 10-07-11, 04:00 PM   #27
denut-L
denut-L's Avatar
Just got done doing it and will post up a video as soon as i get tranny fluids in there. It was an easy job but a headache from laying on the ground to do the work.
Sorry for the crappy pics from my blackberry. This is what i saw when i did it for the first time.
drained the fluids, 14mm socket
Took of all the 10mm bolts holding the tranny pan up, forgot to count how many was there. With the tranny pan off, it sit where the white arrow is pointing
This is what it looked like. i used a short flat to turn it two clicks. Push it in and turning it was easy.
How it looks like after
There it is all done
I just cleaned and scraped all the old gasket maker off and used gasket maker to reseal the pan and slapped it back on. Excited to see the results.
Thanks to GammaLex for bringing this upon us. looks like it'll be a very promising mod to our slow granny shifts
denut-L is offline   Reply With Quote
Old 10-07-11, 04:34 PM   #28
vwynn
very nice man! looks SUPER easy.
question: why not use a rubber gasket from your local parts store made for the GS400s?
something like this
Old 10-07-11, 05:37 PM   #29
sam430
sam430's Avatar
Bravo! !!!!!!!! Btw, did you replace the tyranny oil? Might as well.
Old 10-07-11, 06:18 PM   #30
denut-L
denut-L's Avatar
something like this
Yeah, it's very easy. I'm not planning on keeping this motor very long so i just went the easy way since i had the gasket maker laying around.
Quote:
2 1/2 qts came out and i just refilled it back with new tranny oil.
Oh well, tranny blew up because of something but i'll have to check tomorrow to see what happened.
j/k it felt like it did shift faster going full throttle compared to before but i'll have to see when i race my bud's M3 again. when we raced he would gain on me everytime i shifted gears, due to the slow shifts. Seems like the shifts are also smoother like it didnt shift gears at all. pretty cool i say.
Oh btw remember to unplug your battery before you do this as i got a CEL after this and had to reset it cause i forgot to do it
Thread Thread Starter Forum Replies Last Post
Impressions after 15,000 miles DougHII RC F (2015-present) 18 11-21-15 11:50 PM
Tweak tip for auto Sc shifting! O. L. T. Performance & Maintenance 77 10-15-15 11:34 AM
Does your 430 take a full second to shift from reverse to drive? jpv7774 LS - 3rd Gen (2001-2006) 7 06-23-15 08:51 AM
JDM A340e Aristo TT Shift Solenoid Valves razgs300 GS - 1st Gen (1993-1997) 14 02-23-15 08:14 PM
E-Shift soj17 Performance 1 10-27-03 09:32 PM
Tags
2005, 99, adjust, bilstein, body, feel, gears, gs430, kit, lexus, pan, shift, shifting, shifts, throttle, tranny, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
