GS300 Aristo swap limp mode! Got 6 codes
Old 08-22-11, 10:35 PM
2jzgttegs
2jzgttegs's Avatar
Default GS300 Aristo swap limp mode! Got 6 codes
Can anyone tell me what these codes means for the Aristo 2JZGTE VVT-i motor:
I know code 89 is for throttle body malfucntion
19, 21, 24, 31, 41, 89
I got these codes from the number of times the check engine light flashes
Old 11-01-11, 09:45 PM
dlsoul87
dlsoul87's Avatar
19, 24, 31, 41, 42, 89....did you get a place to check this?...we have alomst the same errors and i did a 2jz-gte vvti swap into an 92 sc300
Old 11-04-11, 07:48 AM
99 GS3
99 GS3's Avatar
I don't have all the codes you listed, but hope these may help..
Old 11-04-11, 07:49 AM
99 GS3
99 GS3's Avatar
99 GS3
99 GS3's Avatar
Old 11-04-11, 08:43 AM
Burton
Burton's Avatar
Don't know if this will help but the codes all seem to do with sensors that run on 5V. Was the car running fine previously or is this a new swap?
Ben
Old 11-05-11, 07:20 PM
dlsoul87
dlsoul87's Avatar
I don't want to hijack the tread, but mine was, I don't know about the original poster. Yes, this was a jdm 2jz-gte vvti swap with the matching ecu
Old 11-07-11, 01:53 PM
2jzgttegs
2jzgttegs's Avatar
Sorry for the late response but this helped out a lot. I replaced the throttle body and it fixed my problems. Thanks 99 GS3
Old 11-08-11, 08:29 AM
G0TB00ST
G0TB00ST's Avatar
How can you pull codes without a scanner?
Old 11-08-11, 01:50 PM
99 GS3
99 GS3's Avatar
Glad you got it fixed!
Counting MIL's like an OBD1 car does, as described in the scanned pages above.
Old 11-09-11, 08:15 AM
2jzgttegs
2jzgttegs's Avatar
Jumping a wire in the diagnosis box from E1to Tc and count how many times the check engine light flashes.
Old 11-09-11, 12:05 PM
G0TB00ST
G0TB00ST's Avatar
Now i need to get me a visual. Thanks
jerimiah87
Build Threads
110
07-31-22 02:04 PM
Ali2GS300
Build Threads
57
07-30-18 02:32 AM
tps3443
01-19-18 05:58 PM
876
Performance
10-24-16 07:23 AM
sstrawsb
IS - 1st Gen (2001-2005)
08-10-09 09:41 AM
Quick Reply: GS300 Aristo swap limp mode! Got 6 codes
