Aristo JOBD Code/Live Data scanning. Greddy/Blitz Displays??
Old 10-02-11, 01:51 PM
  #31
99 GS3
99 GS3's Avatar
Ok I found the Aristo Dash plug only has contacts in the pin locations 4, 7, 13, and 16...
Pin 13 should be Signal Ground according to standard OBD specs, seemingly the same function as Pin Position 5 would be. Except the JZS161 ECU Diagram shows the wire as TC..
Old 10-02-11, 04:52 PM
  #32
99 GS3
99 GS3's Avatar
Here is the ECU chart for the USDM GS300 Dash connector. It does not have the TC wire from the ECU going to the plug in the cabin. This doesn't show pin 5 for some reason but inside the car there is a pin 5 and it is a Brown wire that is just going to ground.
I verified that the TC pin is that same location on both ECU's, the GS body harness uses a P-B (Pink w/ Black Stripe) wire, but it does not come into the cabin with the rest of the harness, it only seems to go to the Diagnostic Port under the hood.
I also verified the "SIL" ECU Pin 11 (White/Grey) is going from the ECU to Pin 7 on the Dash connector, and that it also is the same location for both ECU's.
So it kinda seems that if the JDM Aristo is able to be read by a Generic JOBD Scanner, then maybe all that is needed is to jump the TC wire from the ECU into Pin 13 of the GS Dash Connector. I may have to try this soon and see if it works.
Old 10-02-11, 06:46 PM
  #33
ROPADOPA
ROPADOPA's Avatar
subscribed
sorry to barge in, Im amusing your needing this info to help your tuning what are you using to tune if you don't mind me asking?
Old 10-02-11, 07:18 PM
  #34
99 GS3
99 GS3's Avatar
Originally Posted by ROPADOPA
subscribed
I running MAPECU3 at the moment, I'm happy with it so far. And yes I would also like to monitor open/closed loop for tuning purposes. Although the car currently runs very good and idles smoothly as it is.
It would also be great to get codes back instead of having to count MIL's manually, from what I have found some JDM cars can do this as JOBD is more similar to OBDII than it is to OBD1..
Don't you have the HKS Camp? It's similar to the Blitz R-Vit DS I was posting about on the first page. Does the camp count MIL's like the DS does?
Old 10-02-11, 08:53 PM
  #35
ROPADOPA
ROPADOPA's Avatar
I dont have any issues with my car,
Im working on a customers car
aristo 2jzgte
R154
single turbo
map ecu 2
in a cressida
Have the tccs wiried up and can satisfy it , can drive with no codes.
Looking to use a a scanner to see what the fuel trims are doing would be great. We are working on that too.
Which vehicle base map have you chose for your map ecu?
Old 10-03-11, 12:50 PM
  #36
vanquish2
vanquish2's Avatar
Interesting.....I just pulled up a 99 GS300 EWD and here is what I show
DLC3 plug:
Pin 7 White "SIL"
Pin 16 Black "BAT"
Pin 5 Brown "SG" goes to ground and Pin 9 on ECU ME01
Pin 4 White/Black "CG"
Since it appears we no longer need the "SIL" wire could we see where that goes now versus where it used to go and simply switch it to the TC lead at the ECU and also on the DLC? My diag say it went to J9 connector and then to the ECU. I wish I had the time to looks in to this.....maybe later this week.
What year was your diag from?
So maybe in theory we could just run the TC to the DLC3 and......
Old 10-03-11, 12:58 PM
  #37
vanquish2
vanquish2's Avatar
Also, where did you get your JZS161 EWD? I thought I had a good source for "aristo wiring" but it appears to be the same as what I have here at the dealership....
Old 10-03-11, 05:37 PM
  #38
99 GS3
99 GS3's Avatar
The Aristo does have the SIL wire installed in the DLC, we need that still. It's the GS's DLC Pin 5 "Signal Ground" (as called by the OBDII standards SG would be the ECU Initial) that the Aristo doesn't need any longer. I'm thinking it was a typo and you meant this wire instead.
The Pin 5 Brown "SG" goes to ground and Pin 9 on ECU ME01 is definatly a ground as I tested it. But you say it also goes to ECU ME01, do you know off hand which ECU in the multiplex link this is, as it's not going to the engine control module?
Old 10-03-11, 07:56 PM
  #39
99 GS3
99 GS3's Avatar
  #40
99 GS3
99 GS3's Avatar
Old 10-03-11, 07:57 PM
  #41
99 GS3
99 GS3's Avatar
Old 10-04-11, 06:03 AM
  #42
vanquish2
vanquish2's Avatar
Nice post.....invaluable info for sure! On behalf of many others.....thanks!
I looked again at the EWD and everything I see points to Pin 9 on E2 on the ECM? I have the pdf but I'm not sure one how to post it up to show you. I can do pics but I'm not sure how to post PDF's. Help me out and I'll post it up.
Old 10-07-11, 11:15 PM
  #43
jxzmissile
jxzmissile's Avatar
Hi ya all my name is Pete I have bean watching this thread as I have bean working with a jzs161 engine and need to access the OBD for short and long term fuel trims to aid in tuning Map Ecu2 . So recently me and a friend put a jzs161 ECU in his 99 gs300 it started and idled but we could not access OBD2 . We also wired a J1962 connector as it would be in an Aristo and than as it would be in a GS300 including pin 9 ME01 with no luck . I'm no stranger to jdm Toyota swaps and have had no luck with JOBD , so I have begun to think perhaps I was barking up the wrong tree . I was studying OBD2 and JOBD because they both use the J1962 connector and I started to come across M-OBD protocol which is supported by the Toyota Mastertech hand held scanner the predecessor of Toyota Techstreem . So anyhow I just wanted to share some of my thoughts on this subject as once again I feel as if I'm so close to figuring it all out .
The Toyota Diagnostic Toolset
http://toyota.spx.com/pdf/TY04-168.pdf
The Manual for it which talks about mobd
http://brockandbecca.com/files/fj/Toyota_DTS_Manual.pdf
Old 10-10-11, 05:13 AM
  #44
vanquish2
vanquish2's Avatar
I've got 2 of these old guys here at the dealership that I/we could use anytime......hmmmm
Old 10-19-11, 01:01 PM
  #45
vanquish2
vanquish2's Avatar
99gs...have you had a chance to check the tc wire to see if it works???
Quick Reply: Aristo JOBD Code/Live Data scanning. Greddy/Blitz Displays??
