Installing Invidia Midpipe
Does your midpipe bounce? It feels like the hangars are giving it a lot of play or maybe it's the spring bolts I used. When I shake the exhaust, it shakes a lot. Not to mention, I still need to adjust one side so it sits correctly.
I didnt have a problem at all after installing mine. Never a bounce, creak or rattle. I also wasnt able to use those spring bolts cause they wouldnt fit the axle back I had. Maybe the extra stiffness connecting those two keeps it from clanging around.
Is it safe to replace the spring bolts with normal bolts? I am running an oem axle back. If it is safe and it solves the issue. I don't have a problem switching over. Anything to fix the rattle. It sounds 10x worse when I reverse quick. It sounds like my exhaust is about to fall off.
