Which turbo to go na-t with?
I'm needing some inputs on deciding which turbo to choose for the na-t set up. The engine has 1.3mm hg with ARP head studs, main bolts and rod bolts. All of the seals and gaskets are replaced. I ordered a t4 turbo manifold with 4" intake tube. The transmission is stock for now. I'm looking for a turbo with quick spool and reliable. I know i'm limited by the stock transmission to about 350hp so my goal is around 500 and turn down the boost to 300-330hp till i get the tranny build and fuel upgraded. Thanks.
Thanks for the inputs guys. I did some research on the 6262 and it seems to be a good choice for my set up. But $1500 for a turbo is quite a bit of change. "you get what you pay for" right. I'll just have to dip into the diaper & formula fund. hahaha.
Hey Treadstoneperformance dot com has the Turbonetics T66 T4 ball bearing on sale for $950. Has any one use this turbo? The specs seem similar to the Precision 6262.
Well, i ordered the Turbonetic T66 from Treadstone Performance, their 3" intercooler kit and a Turbonetic Raptor bov. I'm also bidding on a PT 6262 on ebay. Might end up with both. Still shopping for a good 50mm wastegate and AEM F/IC. That will complete my shopping list and I can start the install.
