JDM 2jzgte vvti swap GS300
#138
2- No, I got rid of the oem pump, and added the walbro as it is a performance pump and would supply the enough fuel for the Gt engine. Besides it is capable of suppyling a enough fuel for a good amount of power. The oem pump wasn't quite design for a turbo setup.
3- I've never worked with a supra fuel pump but you do the math, the aristo is a Gte tt vvti, and the supra is a gte tt non vvti and vvit if I'm not mistaken. But again, if there is any difference it shouldn't be far from one another.
#140
Keep in mind the very large diameter of the supra pump, the size is why alot of people do not use them in thier installations.
Adaptings hangers to hold the supra pump is no big deal, but for those reading need to realize that it not a drop in direct swap into the GS, but the DW's and Walbro's are a direct fit.
Also when needing multiple pumps, two supra pumps don't fit through the hole in the gas tank on the GS side by side, so you need to get creative with that.
But yes it's a very reliable quiet pump.
#141
Okay back to the topic!
I got a 21,31 and a 89 code. 21 is the O2 sender, my engine uses one right down by the down pipe and it was cut when I got the motor. I thought I ordered the right sensor from Toyota but I didn't. The sensor I got does not plug in. I hope it's not true but I heard the aristo O2 sensor is not in the US market database and cannot be order. If thats the case how did some of you guys get your sensor cuz I don't wanna believe everybody engine came with a good sensor. Does anybody have one that I could buy?
31 is my Maf air flow sensor which I'm waiting for from the company I got the engine from. Will be here tomorrow. But 89 is also showing up as a supra P1125/P1126/P1127/P1128 code( read a pause ECT- Snow). The vehicle is in limp mode and won't rev above 3k. I've checked all my wiring and the problem isn't there. Are any of these codes triggered my one another if you guys known? As for the rev the only thing I can think of is the maf sensor because the car is running on the gs maf right now that was bad also. I really hope the right maf fixes it. Any thoughts??
#142
#143
#144
I changed the harness side of the plug for my o2 sensor. I think one is a three wire and one is a four wire plug iirc. I called tweak performance and they sent me the harness side plug that I needed with a pigtail and all I had to do is cut the old one off and solder on the new one. Give them a call or send them a PM with a picture of both plugs and they should be able to help you out. His screen name on the forums is dr tweaked.
#145
Thx for the reply guys. The reason I asked the question about the Aristo pump system (JZS161) is that I heard you have to add a return and do some modifing around the pump, which may or may not be the cause of inaccurate fuel gauge readings.
#147
#149
Yeah man, all is good right now. Got that ish figured out. I wanna believe te throttle motor was shorted somehow. I replaced the throttle body and it fixed. my e shift don't work. I got the up shift and down shift wires hooked up but when I go to manual mode of does not work. I'm not worried about that right now cuz other than that the car runs great. I'm currently working on a single conversion on my S147 gs. Within the next few weeks I'll be starting up a build thread on the 2jzgte vvti in an 03 gs. And oh yea, I got the aristo trac ecu I got from u hooked up but my abs light is still on. The light was on before I did the swap so there's probably something else wrong somewhere else. But again, one of the o2 sensors was bad and the cel and abs as well as trac off was on before the swap. I thought it was on because of the cel on the gs engine. But it's not a big deal right now. You with me?
#150
If the abs light was on before the swap you got other issues than the abs ecu.. Likely a abs sensor at the wheels, need to check into that and make sure all the sensors are within spec and none of the wires are broke.
I'm not real sure on the e-shift buttons, as the GTE swap I've done didn't have eshift in the cars to start with, and mine is a manual trans, so I have not had a chance to work on that aspect yet, I hope to get a closer look at one in the future..
Again, glad to see you got it driving well!
