GS300 changed spark plugs to TM plugs & now code P0154, vsc, vsc off light, abs light
Location: ~SIMPLY TUCKED~ scraping the mean streets of L.A.
ok, so last weekend i changed out my spark plugs to the torquemaster plugs. after i put everything back together i get a cel code of P0154 and ABS, VSC, VSC off light came on so i thought maybe my bank 2 sensor 1 o2 was bad. i bought a new one for bank 2 sensor 1 & bank 1 sensor 1 i replaced them both and the code still comes back on along with my ABS, VSC, VSC off light. has anyone had this happen to them...? if so what did you do to fix this problem.
thanks in advance
- john
thanks in advance
- john
^What codes were you throwing? If you are referring to your issues with rough idle in the thread you started, I'm not sure if the OP is having the same problem. Maybe he can elaborate.
OP, I don't know what the issue is, but did she throw any other codes? Usually P0430 or maybe P0153? Maybe its the cat?
thanks for all your time and input guys
- john
yall are thinking way to deep into this. Stick with what your code is bank 2 sensor1. Im hoping you when with parts from lexus. Pm me is you can't figure it out. I will look at the EWD tomorrow if you need me too. Lexus's are too easy to work on to be thinking about random stuff to replace. Let me know man.
try this, its not the same code but i did notice when i was replacing my spark plugs as well the connector for the o2 sensor near the firewall the wires were brittle and cracked. you can try a voltage test on the 4 wires to see if thats your problem. I had to rewire/solder a new connection and all was well after.
