What Brand is the Best Cold Air Intake for the GS??
the SRT intake will give u around 15-20 bhp i think
also if ur on a budget just fab a pipe that goes from the maf to the throttle body, the lexus intake is really good the main thing that holds it back is the resonator which would be deleted if you did that
About the intake resonator, I think that its job is to reduce a little noise, but I think the main job is to add additional air for low end torque, that was my understanding, so it's not as if it hurts performance, it simply causes air to no flow directly from the MAF to the TB, but it's not as if it's a wall in there or anything.
has anybody with the SRT intake considered using a dremel to cut a U in the top of the heat shield so that the "air scoop" from the stock intake could be bolted back into place and provide more fresh cold air to the intake?
I have the weapon r on my 03/GS300. I haven't had any problems with it at all. I got it used for $150 or so. For the money I have no issues with it... I myself can not see paying $499-599 for the SRT. Unless I can get it used. IMO
I have a (true) CAI from LMS. They custom installed it so the K&N filter is OUTSIDE the engine bay down by the passenger fog light. That way you pull COLD air into the throttle body instead of HOT air from the motor! I'm saving up some cash so I can finally pick up a catback exhaust to complement the header, and hook up my NEO. Then I plan on getting it on the dyno to fine tune the bolt ons to see what kind of gains I get. Anyway, try Luxury Motorsports and see if they still sell/install performance parts.
thanks
