This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Second Generation > Performance
Thread Tools Display Modes
Old 02-01-09, 12:49 PM   #1
ElitistK
Trader Score: (2)
ElitistK's Avatar
Quote:
Originally Posted by velella View Post
that doesnt make any sence. the non vvti and the vvti both mount up the same. the only differance u need to worry about is the oil pan which you take off your old motor, the wiring harness is different, and if you go aem that controles the whole engine and trans so i cant see any major problems in this.
that alone, is the nightmare.
you will need a standalone to control a non-vvti gte in a 98+ gs/sc300, or mate the 2 ecu's together.
__________________
ElitistK is offline   Reply With Quote
Old 02-01-09, 10:13 AM   #2
fordsvtmfl
Trader Score: (3)
i was just told the EMS doesnt control the trans in a diff thread...anyways...if i were to do a swap today with a vvti motor..what all would i need? (going from na-t) the engine, trans, ecu and harness, engine mounts, single turbo manifold...what else?
Thanks
__________________
Paypal only
fordsvtmfl is offline   Reply With Quote
Old 02-01-09, 02:20 PM   #3
macd7919
Trader Score: (3)
macd7919's Avatar
man i would go non vvti if i was putting in a gte! for the extra thousand i would save on it i would buy a used aem. than all u need is the gte wiring harness and your good to go! the jdm gte only needs cams, injectors and a single and its pretty much the exact engine as the usdm.
That's a good method to go by if you don't feel like having a tach, speedometer, fuel level gauge, warning lights, etc... etc...I'm not sure who told you that you can just throw a GTE ecu based from a different car in and everything would be fine but they need to check their facts. You will lose almost all functions of the car outside of the motor physically running (just pick up a service manual and look at all the body control functions the factory ecu controls). If you are doing a non-vvti swap you need to wire the car for both ecu's, the harness for the non-vvti is COMPLETELY different from the factory ecu OR the Vvti GTE ecu.
Secondly, have you ever compared the dyno graph of a Vvti GTE to a non-Vvti Gte? Vvti Gte's have up to 30hp more on the bottom end compared to a non-vvti motor, bone stock. The advantage to a non-vvti USED to be the issue of cams because you couldn't find any Vvti-Gte cams outside of the HKS VALCON setup which had to be imported and was $1500. Things have progressed since then and you can pick up whatever combination of cams you want for $600 that drop in the Vvti-Gte so the cam advantage is a mute point. Not to mention the hours of wiring it will save you and the resulting much cleaner install.
Quote:
Thanks
Make sure you get the MAF for the Gte Vvti with the swap, it's different than your stock Maf. Ignitor would be nice though that is the same as the factory ignitor, never hurts to have a spare however.
Your going to have to either mix and match or have a custom drive shaft made, the output shaft from the Vvti tranny is different than the Gs's as well as the shift linkage so you need that with the swap.
You will have to install a return fuel system so you will need at minimum enough fuel line to go from the tank to the rail as well as the appropriate fittings etc....might as well do a pump while your in there as well as swap out the tiny JDM injectors (440cc) for some Usdm injectors (550cc) in case you feel like making some power. You will also need to purchase a resistor pack to match impedance or just make your own which is easy.
Your tach isn't going to work so you need to do a little bit of wiring to get the tach functioning.
If your worried about emissions your OBD ports aren't going to work so you will not be able to pass emissions via a scan. That may or may not be an issue for you.
If your staying stock twins make sure there aren't any broken sensors on the turbos (though it's almost inevitable there will be as the motor is shipped, most can be found used on Supraforums, I even have a few laying around)
You will need to do some shifting of battery cables, power steering res. etc..as the battery is on the opposite side of jdm cars.
Mounts are slightly different, the swap I purchased came with mounts so I had them side by side to compare, the Gte mounts were a little bit different then the GS mounts so I ended up using a combination of both to get the motor sitting perfect. I *think* you could mix and match with 98+ supra mounts as well.
The throttle cable doesn't reach anymore so you will need to pick up a throttle cable, I can't remember which one I used, I don't *think* it was a Supra cable,for some reason I want to say it was a cable out of a truck or corolla or something but it's been so long I honestly can't recall.
Thats about all off the top of my head at the moment.
__________________
1998 GS ~ Bone Stock
2004 KTM 525Exc Supermoto ~ See you in the corners
macd7919 is offline   Reply With Quote
Old 02-01-09, 10:20 AM   #4
MEANDAFAKA
Trader Score: (0)
meth is bad for you, stop doing drugs people. j/j
MEANDAFAKA is offline   Reply With Quote
Old 02-01-09, 02:27 PM   #5
ElitistK
Trader Score: (2)
ElitistK's Avatar
^ are you saying that the gte MAF is a completely separate part # from the ge MAF? is it calibrated differently for reading boost?
the gte maf looks a lot like 98-00 ge maf.
__________________
Old 02-01-09, 02:39 PM   #6
macd7919
Trader Score: (3)
macd7919's Avatar
I can't comment on the way it's calibrated but I know for 100% positive that it is a different part number. I had a 98 Gs and compared all the electronics.
The ignitor was the same exact part number but the Maf, while physically looking the same, was indeed a different part number from the one that came with my swap. I have noticed alot of the swaps don't come with the MAF, I have never tried running the motor on the stock MAF so I don't know if it would work or not. I would be inclined to think there is a reason they are different part numbers however and Toyota wouldn't spend money on using a different part number if there weren't differences.
__________________
Old 02-01-09, 02:45 PM   #7
ElitistK
Trader Score: (2)
ElitistK's Avatar
^ interesting, maybe that's something i should look into. gte ecu w/ ge maf, ge ecu w/ piggyback and gte maf, and ge ecu w/ ge maf all on vvti gte engine.
when i was na-t i borrowed my friend's '06 wrx sti's maf for a day or two and it worked flawlessly w/ my ge ecu. the MAF even had the same denso part #
__________________
Old 02-02-09, 08:27 AM   #8
ROPADOPA
Trader Score: (0)
ROPADOPA's Avatar
im running a non vvti GTE in my car one ECU and everything works except my temp gauge.
The vvti is a better choice for the basic DIY guy. Its a better match, and better technology.
__________________
99 JZS160 2JZGTE V160
ROPADOPA is offline   Reply With Quote
Old 02-02-09, 01:38 PM   #9
macd7919
Trader Score: (3)
macd7919's Avatar
I re-read my post and I came across sounding like it was impossible to do that. I didn't necessarily mean to say it's impossible but it is hardly a trivial endeavor to get everything working of one ecu properly. Even if you know what your doing it would not just be a 5 minute job to wire it up and honestly I wouldn't even go through that headache if it were me and that was my only option for a swap.
Just on a side note, why couldn't you get your temp gauge to work? Should just be a simple exercise in impedance matching right? I don't mean to tell you, I'm posing the question that it should easily be fixed with relatively simple circuit shouldn't it?
__________________
Old 02-02-09, 02:26 PM   #10
ROPADOPA
Trader Score: (0)
ROPADOPA's Avatar
Hard to explain, i may need a new thread.
Think of it this way the car is digital it has it own network of ECUs to make all the car functions work.
The engine ECU takes care of the engine and talks to a few items in the car.
The newer engine that are vvti are digital and can communicate fine with the car ecu's the older (non vvti) engines are analog and don't use the same type of signals.
__________________
Old 02-02-09, 02:38 PM   #11
macd7919
Trader Score: (3)
macd7919's Avatar
No that's cool, I understand whats going on and that was my original thoughts on the matter. I figured since you mentioned you got it all working somehow maybe the temp was just overlooked or something.
__________________
Old 02-02-09, 05:30 PM   #12
ChrisT88
Trader Score: (0)
Intreresting. Could you replace the sensor with a newer digital one?
ChrisT88 is offline   Reply With Quote
Old 10-06-09, 10:39 PM   #13
Deception
Trader Score: (0)
Send a message via AIM to Deception
anyone got any ideas on how to get the speedometer working for a gte vvti with uncut harness and jdm ecu?
__________________
98' GS300 Aristo TT swap
AristoTT Swap | HKS Hi-Power Axleback| Apex'i Limited Ed. RSM | Anceltion Persiana VIP Curtains| Sonar JDM LED Taillight| 19' MRR HR2 Wheels Stgg'd| Infinity BassLink Subwoofer| Denso Hid 5000k| Otto Hid 3000k Fog| Mac Blick Roof Spoiler| JP 3 Piece Spoiler
Complete 2jzge engine, Trans, Ecu, Uncut harness -$1000 obo, Zex Purple Nitrous Tank- $100
Deception is offline   Reply With Quote
Tags
1000hp, 2jz, 2jzge, 2jzgte, build, engine, gs, injectors, lexus, nat, stock, tach, tachometer, vvti, work
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
