Brian Crower 264 2JZ-VVTi Cams: Install, Tune, Results, and DIY
Old 07-07-08, 11:00 AM
JeffTsai
JeffTsai's Avatar
Default Brian Crower 264 2JZ-VVTi Cams: Install, Tune, Results, and DIY
Ok, I can't confirm for sure but I think I'm one of the first few people to pick up a set of these.
A shot of my GTE Setup
Start off, remove the accessory belt. Then remove the water pump and power steering pulley(optional but it give you more room to work). You should loosen the pulley bolts before you take the belt off because that way there's something holding the pulley in place so it won't spin. Then remove the spark plug cover and the upper timing belt cover. The lower one stays on.
I love the GTE motor becuase it took me a whole 10-15minutes to get to this point. No need to screw around with that annoying GE intake manifold that wraps over the top.
Get under the car, loosen those two bolts on the timing belt tensioner. It's a real pain to get in there if you don't have the right tools. Extensions, U-joint, and for reinstallation a power tool really helps to get the bolt threaded back in.
JeffTsai
JeffTsai's Avatar
Remove the bolts on the cam pullies. On the VVTi cam, make sure you put some rags under to catch the oil or else it's going to go everywhere and leak on the timing belt. Then also remove the valve covers. Also, you should be able to slide of the timing belt.
Most of the important stuff is stripped off here.
Remove the VVTi solenoid oil line. Keep in mind, put a rag under that to catch oil as well. It shoots out a good bit. Another tip, use a screwdriver or something to pry the camshaft out. It's going to want to stay wedged in there and you're going to have to work it a little bit to remove it.
What you've all been waiting for. What do the BC cams look like? They look stock lol. Keep in mind my engine is a GTE so there's that weird looking pattern on the exhaust camshaft near the front.
Close up to know it's legit lol.
Put all the stuff back in and double check the clearances with a feeler gauge and reshim if necessary. You should know how to do this if you're attempting something like this.
If I remember right, the clearance specs are:
Intake .15-.25mm, Exhaust .25-.35mm
Once clearance is checked, put on the pullies and recheck timing to make sure it's spot on.
Button everything up and you're ready to roll.
Old 07-07-08, 11:01 AM
JeffTsai
JeffTsai's Avatar
Results:
I got it tuned and drove it around for a while. One thing that sucks, it doesn't lope lol. It sounds just like stock. According to the butt dyno, I make more power mid range and the turbo spools up a tad faster. My top end didn't have much of a difference, but that could be due to my turbo being small. The mid range definately has a very noticable difference compared to before though.
Old 07-07-08, 11:02 AM
macd7919
macd7919's Avatar
And the results after tuning are........(drumroll)...........you beat me to that last post by 2 seconds, lol....did you pick up a graph of before and after? What kind of midrange did you pick up (did you get actual before and after numbers)? What are you using to control Vvti with the bigger cams? I know you can put bigger cams in and run it on the stock Vvti control but you wouldn't be seeing max gains with that. Are you using something to alter the factory cam "timing" profile?
Old 07-07-08, 03:13 PM
MrExecutiv
MrExecutiv's Avatar
wow Jeff. Never ends. lol. Your Motor looks amazing.
Old 07-07-08, 03:17 PM
Euphoric
Euphoric's Avatar
Sweet! Gonna need 272's or bigger for some lope action though.
Old 07-11-08, 08:17 AM
Donuts
Donuts's Avatar
This is such an Awesome Job.. indeed also very informative.. !
i thought only HKS Manufactured ValconPro vvti cam kits..totaly didnt now that crower manufactured for VVTi vehicles !
soo... what did you use.. to control the VVTi... with ur new cams.. ?!?!
V-Manage by Greddy ?!?! update us.. This is amazing !
oohh.. and how much they did cost you ?!?!?
Kool.. thnx for this awesome Thread !
keep us informed !
Old 07-11-08, 08:56 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Any new HP number jeff... The engine looks amazing and the guys with boost I'm sure appreciate all your hard work.. Nice job..
Old 07-12-08, 07:31 PM
TheMadGS3
TheMadGS3's Avatar
Badass Jeff! Your engine bay looks sick.
On a side note...are you running stock ECU as well as EMS? If so are they both in the stock box?
Old 04-30-12, 05:13 PM
Mer257
Mer257's Avatar
Hey jeff in what sequence did you torque down the cams?
Old 04-30-12, 06:27 PM
TRBOSQRL
TRBOSQRL's Avatar
i have those in my car and can not get the idle to set wht are you tuning with
Old 08-16-14, 08:46 PM
ELLeon
ELLeon's Avatar
Hey Jeff, do you happen to have a video of how the dyno went or how your car sounds with the cams now?
handoi9
04-18-14 04:20 PM
Trouble-T
07-22-10 10:05 AM
flashpcs
04-18-09 10:38 AM
cbibb
04-11-09 04:05 PM
JDMS2k3
Performance & Maintenance
14
04-08-06 01:33 AM
Quick Reply: Brian Crower 264 2JZ-VVTi Cams: Install, Tune, Results, and DIY
