Intercooler for GS300
Old 06-14-08, 03:24 PM
ElitistK
ElitistK's Avatar
i'm going to run 24x12x3 w/ 3" outlets and it fits perfectly between the crash bar and the ac condenser. You can even fit a 4" in there but 3" should be enough in most cases.
Old 06-15-08, 06:12 PM
AristoKing
AristoKing's Avatar
yeah im going to stick with the 3" isted of 4" everybody tells me the same thing.
thanxxxx man.
Old 07-31-08, 06:05 PM
nik911sc
nik911sc's Avatar
Default Dimensions
Hey guys I am looking at FMIC's too.
When you quote dimensions - are you quoting overall dimensions or the core size?
Lastly, what is the best size to go for without modification to vehicles structure i.e. cutting and trimming etc.
Old 08-07-08, 01:17 PM
black_gs99
black_gs99's Avatar
blitz has a good intercooler kit for anyone with a 2jzgte swap but i think it costs a good amount of money...i was looking into it when i was planning on doing the swap...
Old 07-29-13, 05:21 AM
adamgamz
adamgamz's Avatar
Originally Posted by macd7919
I'm running basically the same dimensions as above but 4" thick.
I'm bringing this one back from the dead. My intercooler "CORE" is 24 X 12 X 4 however I had to remove the crash bar to make it fit and it was very tight, it wound up putting pressure on the bumper cover and it rubbed on the lower a/c line and eventually made a hole in it over the years. Right now I'm in the process of redoing my intercooler, installing a new A/C line and moving around my intercooler pipes to make room for my new Zirgo fans.
The problem I'm having is I can't find my old bumper reinforcement so It's hard to take dimensions without that installed. I want the largest intercooler I can possibly fit as I'm running over 800 HP to the wheels. From reading this thread it looks like Burton has the largest one here, Burton if you're still here does your intercooler clear the crash bar / A/C lines well? I just ordered one similar so I'm going to see how it works out.
Old 07-29-13, 08:43 AM
sakataj
sakataj's Avatar
why not get a tubular crash bar made around it Adam?
Old 07-29-13, 10:23 AM
adamgamz
adamgamz's Avatar
The crumple zones won't work correct, also there is no room at all with the stock bumper cover, it's already very tight hitting the bumper cover up front and hitting the lower a/c line on the condenser in the rear.
Old 11-03-13, 04:07 PM
00Formula
00Formula's Avatar
I had planned to use a Treadstone unit in my swap.
Overall Size 26.50" X 12.00" X 3.50"
Core Size 25.00" X 6.00" X 3.50"
3.00" Inlet/Outlet
1000 Hp efficient
http://www.treadstoneperformance.com...cooler++1000HP
Old 11-10-13, 12:17 PM
00Formula
00Formula's Avatar
I guess the outlet position is not ideal on the above Treadstone intercooler. This one is rated to 1000hp, but has a better outlet location.
-Core Size, 12.5" X 22" X 4.5"
-Overall length 30"
-Less than 2psi pressure drop at max flow
-3" inlet/outlet
-4.5" core, 1469 CFM flow rate, 860hp efficient, 1.5psi drop
http://www.treadstoneperformance.com...rcooler++860HP
Or this one that is 3.5" thick.
http://www.treadstoneperformance.com...rcooler++760HP
Old 11-11-13, 05:47 AM
adamgamz
adamgamz's Avatar
I bought the 24 X 12 X 3. It did fit well behind the crash bar, I had to bend my a/c line into a much tighter bend where it enters the condenser. My car has gone 10.2 @ 140 MPH with this intercooler and I expect to go deep into the 9's @ 150 MPH+ in the coming weeks.
CHASER4LIF
GS - 1st Gen (1993-1997)
12-02-10 12:53 AM
kyang91
09-09-09 01:40 PM
THE.K.W.C
03-29-09 09:43 AM
Bigrahizzl
Performance
09-21-07 12:25 PM
Quick Reply: Intercooler for GS300
