Expected life of a GS400 Engine and Transmission
Old 02-01-10, 07:11 PM
GS300-2002
GS300-2002's Avatar
I can see the engine in the 300 and the 400 lasting any where from 300k to the apocalypse, they are extremely reliable, but the transmission... not so much. I really dont like the tranny in my gs and my dad's LX dropped a tranny before the warranty went out, phew, but lexus seems to have gotten their stuff togther now. Except for the whole 8 gears is way too many in an ISF thing but thats another thread
Old 02-02-10, 10:14 AM
ICEBERGS
ICEBERGS's Avatar
I drive the dog snot out of mine and I got 230kmiles before it dropped a valve and i had to replace it, 3 months after putting in a new tranny!! its sucks! i think i just have bad luck but these cars will last you as long as you take good care of them!!
Old 02-02-10, 10:42 AM
jcat_350
jcat_350's Avatar
if maintained properly, you should easily get 250-300k out of it before a rebuild is required, if not more.
Transmission, if you install a cooler it will extend the life but the a650(e) transmissions are usually good for 200k or so before needing a rebuild, again with proper maintenance they will last longer
Old 08-14-13, 09:19 AM
jsarg419
jsarg419's Avatar
223351 on my GS4 only oil plugs and two timing belt changes took it to the governor just the other day plenty of power left still runs smooth
Old 08-14-13, 09:09 PM
JeffTsai
JeffTsai's Avatar
I rebuild a bunch of these for performance purposes. When I tear down a stock engine and transmission for cores to use, usually most at 150k miles range. The cylinder walls still have crosshatches, the engine bearings are pretty much as smooth as the day they left the factory, and everything is still in spec. I don't see why these things can't easily go 2-3x more that amount of miles without even breaking a sweat. In the transmission, the latest one I tore down had 186k miles on it and the clutch packs still had the original print readable! I'm talking about the part numbers they print on the face of the clutches, yes on the part of the clutches wearing and making contact. After 186k miles, the numbers are still readable and this transmission was not very well taken care of either! My guess is that a car that has had on time maintenance on everything will easily last 300k+ and probably 500k and beyond.
Old 08-15-13, 04:05 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
is it true our our transmissions don't have a tranny filter? Someone said that to me the other day but I thought we did
Sent from my iPhone using IB AutoGroup
Old 08-15-13, 05:20 AM
kamlung
kamlung's Avatar
thought it had a screen.
Old 08-15-13, 08:22 AM
tmf2004
tmf2004's Avatar
that's what I thought but not a filter
Old 08-15-13, 08:29 AM
HI98GS
HI98GS's Avatar
It has no filter. There is a very fine screen and that's about all.
Old 08-16-13, 12:12 PM
GS4VIPbOSS
GS4VIPbOSS's Avatar
Prolly 300+
Old 11-27-14, 08:28 AM
Giggzz
Giggzz's Avatar
Bought my 99 gs 400 in 2000 with 12k and now have 272k. I'm actually looking at changing motor and tranny mounts since it's still orginal.
Dyslexi
07-02-19 09:11 PM
TomKog
RX - 1st Gen (1999-2003)
08-03-17 12:32 PM
lkmljp12
04-19-13 04:04 PM
Bdiepp
04-19-08 10:59 AM
chuckb
GS - 1st Gen (1993-1997)
25
05-18-05 07:33 AM
Quick Reply: Expected life of a GS400 Engine and Transmission
