Official Tranny Cooler Thread for the 2GS
#169
For those who have the tranny coolers, what kinda temps are you guys seeing, while driving, at a stand still, in boost ( or none) ... As I've talked to couple people, the 200 degree point is where you should back off an let tranny get back into the 160-170's ... Of course this would require to have a tranny temp gauge as I do.
#170
BahHumBug
im gonna end up re-routing this to go from the OEM cooler to the aftermarket cooler and back to the tranny instead of how i had it routed since the tranny should said this would be best for cooling but this is the setup i have used
so far this is a list of stuff im using
GODMAN FITTINGS
Quantity Of 6 -06 Straight Hose End Aeroquip Part # 610-06A
Quantity Of 1 90 Degree Male Elbow -06 AN x 3/8 NPT Part #AN822-06-06
Quantity Of 2 -06 Flare x 1/2-20 MIF Part # 2000
Quantity Of 2 Compression x -6 AN Male- Steel Part # 3080S
Quantity Of 1 90 Degree Male AN To MNPT Swivel -06 x 3/8 Part # 335
Quantity Of 2 -06 Flare Union Part # AN815-06
Quantity Of 2 -06 45 Degree Hose End Aeroquip Part # 645-06A
Quantity Of 18" -06 Stainless Steel Braided Hose Part # FBA0600
Quantity Of 10 9/16 x 9/16 Separators (Fab-0600) Part # 2928
Quantity Of 10 5/8 Adel Clamp Part # 2582
the last 2 in blue you can use either or....i like the separators better than the clamps though they look 100% better
JEGS Fittings
Quantity Of 2 (1 Pack) -06 AN Tube Nuts Part # 555-100382
Quantity Of 2 (1 Pack) -06 AN Tube Sleeves Part # 555-100392
RUSSELL FITTINGS
Quantity OF 2 -06 AN Male To 14mm X 1.5 Metric Male Adaptor Part #799-670520
OEM FITTINGS
Quantity Of 1 Nut, Flare (For ATM Oil Cooler) Part # 1649550020
Quantity Of 1 Inlet Sub-Assy Part # 1649774760
Quantity Of 2 OEM Toyota Tranny Fitting O-Rings Part # 9030111006
OTHER PARTS
Quantity Of 1 Vise Jaw Inserts-Aluminum Part # 25251
Replacing all the hard lines in here from the transmission to the OEM cooler
http://lexus.sewellparts.com/oem-cat...S430-2001.html
GODMAN FITTINGS
JEGS Fittings
RUSSELL FITTINGS
OEM FITTINGS
OTHER PARTS
it's the trans-side fittings I'm looking for. The trans is (2, in/out) 16mm x 1.5 fitting Inverted Flare right?
#171
you are just wanting the part #'s that i used for these then (the 2 on the left?
and the ones in the middle with those screwed in then?
OEM PARTS
RUSSELL FITTINGS
GODMAN FITTINGS
#172
It doesn't matter which fitting you replace it will work the same either way..
At the trans like Sakataj is doing would be these: http://www.jegs.com/i/Russell/799/670520/10002/-1
#173
BahHumBug
OOPS....i put the wrong ones at first i thought u asked me for the ones coming off the OEM cooler dumb me...
OEM PARTS
RUSSELL FITTINGS
GODMAN FITTINGS
OEM PARTS
RUSSELL FITTINGS
GODMAN FITTINGS
16x1.5 inverted is if you replaced at the hardlines, 14x1.5 is to replace at the trans, if replacing at the trans the end type doesn't matter at there is no bottom, the o-ring makes the seal.
I plan on going with -8 hose and a bigger cooler as I plan on bypassing the in-rad heat exchanger (since i'll be switching it out soon for an alum piece).
http://www.jegs.com/i/Earl%26%23039%...19EFH/10002/-1 would be the correct piece right? with the OEM O-Rings of course.
The sizing is dependent on if the cooler I want is available in -8an in/out, if not then -6 it is
#174
ahh perfect, thanks gents.
Keep in mind you can defiantly overcool the the fluid as well which is bad if your putting some kinda of huge cooler on there. A thermostatic valve can prove useful when the trans is not under heavy load or in the winter.
#175
BahHumBug
Upsizing the diameter isn't necessarily beneficial. As you increase the volume you are moving the velocity will decrease because trans is still pumping it at the same flow rate. -6 to -8 is marginal and should be fine either way with a single or dual coolers. But any system can only flow as much as it's smallest orifice which is the bottle neck. So you can put a -16 line on it, but the stock fittings in the tranny have the i.d. of a -6 so it's not providing any real benefit.
I'll do a little more research nonetheless before I order parts.
#176
I noticed a lot of you are mounting the transcooler wrong the fittings should not be pointed downward it should be pointed up or pointed to the left side or right side. Having the the fittings pointed downward can cause a air pocket making the cooler less effective.
Look at this PDF link from B&M...
http://bmracing.com/wp-bnmcont/uploa...er_techdoc.pdf
#178
A year since the last post (sue me)
I added a trans cooler to my '03 GS300 not so long ago. I actually dc'd the line and ran it to a bucket so I could observe the flow. For me the passenger side line was the return. This might not be the case for a GS400/430 etc. Never hurts to verify.
#179
I am looking for some 1UZFE owners w/ Trans coolers and also have needle or digital gauges. Will those who do, if you have a moment, let me know what your High temp readings are? I'd really like to compare yours to mine. I'll be installing a PI Dragon TC shortly and would like some normal/high temps info from you guys. I'm trying to decide whether I should switch to Amsoil, or if I can stay w/ the Toyota IV ATF. Even in stop 'n go traffic, my gauges (oil or trans temp) rarely go over 205-210F. Just had the transmission flushed/filled by Toyota about 6 mnths ago. I've read in forums that Amsoil runs cooler, but by how much? I haven't seen any real numbers. If any of you HAVE switched, and know the operating temps' difference, that info would be GOLDEN! Thanx in advance...
