synthetic transmission fluid question
Old 03-28-07, 12:00 PM
gadgeeets
gadgeeets's Avatar
Default synthetic transmission fluid question
i was wondering is it beneficial to flush the transmission and use synthetic fluid, and at what mileage should it be done..maybe even flush the powersteering fluid and do the same..
Old 03-28-07, 05:47 PM
Alexus_300
Alexus_300's Avatar
Well, the beneficial part of flushing your transmission and power steering is a maintence matter more than anything. I've notice that my transmission shift better when I flush the fluid. So I highly recomend that you go out and get yourself three quarts of toyota Type IV transmission fluid and do a simple flush and drain. It doesn't hurt to have new fluid in the transmission as it can only help lubricate better.
Old 03-30-07, 11:04 AM
benzo555
benzo555's Avatar
Well if u plan to go synthetic, dont use toyota type IV fluid as is dyno fluid I was told.
Starting in 2004 the GS had synthetic tranny fluid from the factory already.
Old 03-30-07, 08:09 PM
Alexus_300
Alexus_300's Avatar
The only two transmission fluid that the A650E transmission that is equipped in our cars that we can use without trickly the CEL is the stock Toyota Type IV fluid and the Amsoil synthetic transmission fluid. Both of these fluid are synthetic from factory. Don't ask me how I know this but trust me when I say those are the only two fluid that can be used in our transmission.
Old 03-30-07, 08:15 PM
maintrain
maintrain's Avatar
I noticed smoother shifts after my trans flush with amsoil synthetic.
Old 03-31-07, 09:24 AM
Cosworth
Cosworth's Avatar
http://www.mobiloil.com/USA-English/..._ATF_3309.aspx
Be absolutely certain you refill with the correct fluid. This Mobil ATF 3309 meets Toyota type T-IV.
Old 04-03-07, 12:38 PM
benzo555
benzo555's Avatar
Alex
Interesting.. I will confirm with a buddy of mine at the Lex dealership when I get back in town.
Old 04-04-07, 07:10 PM
jbw
jbw's Avatar
How would Mobil ATF 3309 compare with Mobile One synthetic for use in second generation GS3? I've used Mobile One ATF very successfully in my 99 Isuzu Trooper...184K miles.
lexusben
08-19-11 06:19 AM
mrekid
RX - 1st Gen (1999-2003)
14
01-28-07 08:41 PM
Bobk528
16
09-26-05 07:34 PM
sc400nos
Performance & Maintenance
18
01-12-05 05:31 PM
Quick Reply: synthetic transmission fluid question
