2jz-gte Conversion
Old 04-20-14, 05:38 PM
  #406
0flav85
0flav85's Avatar
Default 2jz swap
Originally Posted by durellusmc
Ok guys been reading this thread immensely, here's the deal... I am the proud owner of a jzs161( currently stationed in Japan) and I have an 03 GS430 back home, with that being said I will be pulling the 2jz engine tranny with driveshaft. What else would you guys suggest I pull just for the swap, I really don't wanna pull parts if they aren't really needed you know. As far as ecu I plan to pull everything associated with it any other items to pull? Thanks in advance
semper fi brother, you should get the rear differential and if your not planning going big turbo right away you should get the fuel pump and fuel pump cradle, the jdm fuel pump cradle or whatever its called will correct the fuel gauge issues people got with the swap. when you leaving japan?
Old 08-31-14, 09:37 PM
  #407
Boosted400
Boosted400's Avatar
Very informative
Old 09-06-14, 06:46 PM
  #408
Barry646
Barry646's Avatar
I'm about to do the same swap, but I want to keep the e-shift. How exactly do you get this to work on the 4 speed tranny? Any help would be appreciated.
Old 09-06-14, 06:58 PM
  #409
iToaster
iToaster's Avatar
There's a guide around here that details running wires for a non-e-shift equipped car. I'd hunt that down and see if you already have wires where it tells you to put them. I would wager that you probably do and that it should just plug in and work.
Old 09-10-14, 02:29 PM
  #410
ChiefSeeth
ChiefSeeth's Avatar
IS THERE ANYWHERE I CAN GET AN ARISTO (OR ANY 2JZ-GTE) ENGINE WITH LITTLE TO NO MILES ON IT? or has it been completely put out of production. If so where do i get it/import it from?
Old 09-10-14, 03:01 PM
  #411
offbad
offbad's Avatar
try google.
3 4 5
Old 09-10-14, 03:25 PM
  #412
twojayzee
twojayzee's Avatar
If your talking about a complete motor assembly with harness etc. the answer would be no. JDM is still the least expensive source.
You could get a complete a complete assembly and have it rebuilt...
Old 09-11-14, 12:42 PM
  #413
angus
angus's Avatar
I know many people who run the JDM gte motors and have no issues, the motors most likely have 100k kms or more which is not too bad.
Old 12-16-14, 09:04 AM
  #414
tn96dc
tn96dc's Avatar
Besides using the srt fuel jet killer, what is another option for the fuel problem? I found one the other day that looked like it only consisted of a a t fitting and a couple of hoses. Now I can't find it to save my life! Help! Lol
Old 12-17-14, 03:35 PM
  #415
nyc80rick
nyc80rick's Avatar
https://www.clublexus.com/forums/per...isto-swap.html
check this thread believes he addresses that problem
Old 10-26-15, 02:23 PM
  #416
angus
angus's Avatar
Does someone have the wiring info for the two body plugs if I do not have the orange and grey JDM wire caps?
Old 10-26-15, 05:10 PM
  #417
angus
angus's Avatar
I don't know if anyone is running this setup but I am considering:
- Aristo GTE vvti engine
- GS300 A650E tranny
- GS300 engine harness
- GS300 ECU
- AEM FIC
- 550cc injectors (maybe larger)
Any input?
Old 04-22-16, 01:16 PM
  #418
Lexsantiy
Lexsantiy's Avatar
- GS300 ECU
- AEM FIC
Any input?
Would this setup make a OB2 smog check pass, because you have the GS300 ECU? You would need a EGR head installed i understand from what ive been reading.
Old 04-22-16, 07:05 PM
  #419
99 GS3
99 GS3's Avatar
- GS300 ECU
- AEM FIC
Any input?
The real question is what's controlling the twins vsv's?
Old 09-14-16, 10:21 AM
  #420
super51fan
super51fan's Avatar
Im debating on making the swap here soon but the only thing holding me back is ride quality. Does anyone have info on how the comfortable the car drives before and after the swap?
Quick Reply: 2jz-gte Conversion
