Check Engine light
05-22-06, 04:29 AM
Check Engine light
i had an check engine light on then i check the code p0420---Catalyst Efficiency Below Threshold (Bank 1) anyone know whats this??thankz
05-22-06, 07:25 AM
Quote:
I am at work but I can check when I get home in my manual.
Did you so a search on it and see if anyone else has discussed it??
Jonny
05-22-06, 04:37 PM
05-22-06, 05:40 PM
Thankz alot for your time but do you know where's the sensor in my car located?? 01 lexus gs300
05-23-06, 03:53 AM
Here you go
05-23-06, 04:22 AM
Another pic.
05-23-06, 04:02 PM
Thank you for your time..now i have to go get it check to see which one is bad...is there anyway i can check for myself???
05-24-06, 05:03 AM
I'm not sure. maybe check w/ Lex*toy
05-28-06, 05:33 PM
One way to check is using the Lexus scanner. It would be able to tell the voltage before after cat.
JPI
05-29-06, 02:10 PM
that should be the o2 sensor after the cat on bank one, see the picture in the other post for which is bank one. that's the sensor that measures air after the cat, and since the codeyou are getting is a cat code it has to be the sensor that measures after the cat. and the code already told you it was on bank one. hope this helps!!
Lveyolfe
05-14-14 09:55 PM
dell2011
04-20-11 05:12 AM
OnyxGS300
GS - 1st Gen (1993-1997)
11-10-07 07:49 AM
howiedoit
SC- 1st Gen (1992-2000)
01-30-02 01:08 PM
01 ,
2001 ,
2003 ,
300 ,
bank ,
check ,
code ,
engine ,
es300 ,
gs ,
gs430 ,
lexus ,
located ,
ls430 ,
lx470 ,
o2 ,
oxygen ,
po420 ,
sensor
