tps setting,
tps setting,
my service manual says to set it at 15.2% the scantool software i am using will jump from 15.3% to 14.9%
will that .1% make a differance, i am still having a issue with the Throttle cutting out, holding the pedal when this happens trac lights come on.i did change my tps,even
removed my tps from my tundra just to make sure i didin't get a defective part,same part number is used.
any one have any idea?thanks
Why are you replacing the TPS? I don't know what book you are reading or getting the info from but the spec on TPS is 14.4-16 %. Have fun replacing it and don't strip the bottom screw
JPI
JPI
