HELP!! Turbo guys MKIV NA 2JZ-GE w/ 2nd Gen rx-7 injectors
Hello peeps, I've did some surfing on SupraForums, but couldn't seem to get the proper information. My question is whether the rx-7 2nd generation 460cc's injectors fit perfectly without modifications. I know for a fact that they're low impedance vs. my high impedance stock 330cc injectors. That's okay because a simple resistor placed on the wire of the low impedance injectors would bring up the ohms. My main concern is whether it'll drop right in the na non-turbo fuel rail? I would hate to spend more money modifying the rail. Some of the info I received from the forum is that rx-7 injectors work, but they don't seem to indicate whether it's fits perfectly, or whether work is required on the stock rail. Please help in anyway you can. Much appreciated guys. Peace out to everyone.
actually the FC N/A injectors are high impedence, you can also get high ohm 550's if you choose the correct year...if it helps at all - they're interchangeable (size-wise) with dsm injectors...
Marshall
Marshall
I have test fitted the rx7 injectors and they fit the rail perfect, the only difference in size was the rx7 injectors being 1/4" longer, but they still fit in the rail.
I was not aware dsm injectors were the same size.
Forum Administrator
Johnnyboi, you are not welcome on our forums.
