What are the wonderful uses of Toluene?
Toluene
Does anyone know about this stuff? From what I've read it is 114 octance and is available in paint stores as a solvent. I also learned that the Japanese have used it as an octane booster. Does anyone have any experience with it? What kind of performance increase could I expect if the octane was raised to about 97?
yes, it is used as a cleaning aide in building boards (soldering)
it is HIGHLY flammable, and eats away your skin....get it on your paint and watch it fade away
I wouldn't suggest it
anyone here actually USED it before? ok then
technics, my friend when he was running his stock turbo WRX with its learning ECU would run Toluene at like a 1/4 mix or something....
this resulted in a downpipe, testpipe, catback, stock intake, stock turbo car running ~17psi on stock tires to run a 7.9 in the 1/8th computer saw the extra room and advanced the ignition furthur too...
toluene works very well to a limit... wouldn't go too much mix on it tho...
and guys... gasoline is ALSO very flammable and can irritate your skin... should we not use that either?
NOW... if you're using this on a stock car, you wont see an ounce of performance difference from it at all
i'd be looking other places to increase your performance
Agree with Bean. I've seen plenty of people use it to good effect. Vipers, Supras, WRXs. Most I'd heard of was 20% with no real issues.
Matter of fact, isn't there already a buttload of toluene in your fuel?
no harm, no foul right?
Edit - We are saying the same thing. No gains.
Em.. how did he get exposed to it that much? Industrial? The one time I saw a guy mixing it in his tank, he did use a full face organic respirator and gloves.
As Em says, anyone who runs down to their local bulk chemical supply and buys large quantities of an odd chemical without checking out the safety requirements... well, you're looking for trouble. I presume the big warning labels all over the side of the drum on handling and storage should tip you off that this isn't really safe. If you ignore all the warnings, and don't have that kind of common sense, well you probably shouldn't be working on your car. This applies to grinding, welding, printing circuit boards, stripping paint...
Just another "have some common sense" message
Originally posted by legendary
I totally agree Bean, but look - ^^ his car is stock. He is running a stock SC300. I figured someone would say something about the flammability, that was a joke. As we have discussed in many other threads, adding a higher octane fuel than specified for in a stock vehicle will not net any huge gains, if any at all.
Hey, watch it! Hopefully the car won't be stock for long! I wanted to see if anyone actually had any experience using it.
Bean, thanks for the insight.
I don't recall saying I had 200 gallons of toluene in my garage ready to use.
