S2000 Seats install (On-Going)
Old 02-20-17, 10:58 PM
GTX580
GTX580's Avatar
Default S2000 Seats install (On-Going)
I bought some TAN S2000 seats for a really good price and plan to install it in my SC . I am replacing an older bride seat. It is tough to drive long distance in a fixed bucket...S2K can recline a little bit which helps.
The front two holes are not spot on. The S2K front holes are wider and as SF thread state, you can even ream it out and bend the bracket slightly to make it fit for the front.
The rear holes are no where close to the SC. Luckily I did not throw away my stock SC bracket and is likely going to use it.
At this point, I plan to cut the bracket off the SC and weld it onto the S2K rail. I only have a Tig so this might be tough. Any suggestion is always welcome.
Anyhow, just threw the seats in the car to see how it looks. More progress coming....hopefully.
Old 02-21-17, 12:34 PM
GTX580
GTX580's Avatar
Driver Seat - 2 hole mount side.
Driver Seat Door side
Front bolt
Front bolt #2
Old 02-21-17, 03:14 PM
Blkexcoupe
Blkexcoupe's Avatar
I've seen many threads about installing s2k seats over the years, but no one ever gives an accurate description of what is involved. I'm glad you posted this.
Old 02-21-17, 08:53 PM
GTX580
GTX580's Avatar
To remove the bracket, drill out the metal rivet and the spot weld.
I
I welded the back right bracket to a 3/8 steel and bolted onto the stock s2k rails. I think this is more secure than just welding the sc bracket to the s2k rails.
thanks!
moar pictures.
Old 02-23-17, 09:20 AM
Blkexcoupe
Blkexcoupe's Avatar
That looks really sketchy at first. After thinking about it, after market seat brackets aren't that far off from the design you made. Does the seat sit at a crooked angle with your design?
I wonder if there is clearance to use square tubing as a spacer to eliminate the oem bracket completely. You could use one long bolt to go through the s2k seat into the square tube, then directly into the chassis with a reinforcement/nut plate underneath the car.
Old 02-23-17, 01:44 PM
GTX580
GTX580's Avatar
Ya I think that would be the way to go. I don't have an airbag equipped either so I might do that.
Old 02-23-17, 09:10 PM
Blkexcoupe
Blkexcoupe's Avatar
I would also recommend installing end caps on the square tube, so you can drill through it in order to keep the bolt aligned and centered on the tube. The reinforcement/nut plate is commonly used as an anchoring point for harnesses, so it should be strong enough for the seats.
Old 03-13-17, 05:36 PM
GTX580
GTX580's Avatar
All done.
Old 03-29-17, 10:15 PM
Golfer2000
Golfer2000's Avatar
Does anyone know where I can pick up some of those seat brackets? Id rather not cut them off of my supra seats. Thanks!
Old 03-31-17, 12:21 PM
mr913
mr913's Avatar
bro what steering wheel and how did you get it installed???
Old 04-01-17, 09:23 PM
GTX580
GTX580's Avatar
2012 CT200H steering wheel with airbag cover. I have more pics in my build thread, on page 1 I believe.
durps
SC- 1st Gen (1992-2000)
14
04-18-13 09:25 AM
V8KLLA
31
07-26-12 06:31 PM
chnk
20
11-21-10 09:35 AM
jvsc300
30
09-21-09 01:27 AM
Bryan858
SC400 / 300 Classifieds
10-30-07 06:24 PM
Quick Reply: S2000 Seats install (On-Going)
