MTF vs ATF how to tell difference ?
Hi, I just got my 60k service done. On the sheet, I see automatic transmission fluid OTH (others?)
I know I was suppose to get this fluid changed or flushed but my car is a 5 speed! Shouldn't it be MTF instead of ATF ?
Is there any way for me to tell if they've used ATF or MTF? what are the differences that I can use to distinguish... the shifting now feels a bit more notchy than before so that's why I'm concerned.
I'd get it checked asap. The wrong tranny fluid can cause damage. FWIW, I switched to Redline MT90. Works like a charm. Have run this fluid for two plus years now. Shifts smoother than stock.
5-speeds shouldn't have a dip stick! They should have a fill hole on the side of the tranny.
Granted I don't own a manual Lexus, but I've never seen a manual car in general w/ a dip stick.
You gotta jack up the car and get under it. Some even have a little "window" to see if it has enough oil in it.
Keith
Keith
shroomysou
31
12-24-19 04:04 AM
