Window regulator 69802-24033 or 69802-24032?
Old 02-13-17, 06:08 PM
Modenaro
Modenaro's Avatar
Default Window regulator 69802-24033 or 69802-24032?
Heard a loud bang today on the road, like a base ball hit the dr side of the car.
It was the dr side elect. window. Motor still works, glass isn't broken.
But when I rolled it down, it stayed down................Lifted it up manually and taped it in the up position.
Looking at L side window regulators for my build date 8/93 and VIN it calls for #69802-24032.
The car was sold as a 94.
With #69802-24033 being used right after that later in the production run.
Is the later part number 69802-24033 an improved part I can use?
Or should I order what's called out #69802-24032 as they are different parts all together?
(Best online deal on one?)
Thanks..................In advance!
Old 02-13-17, 08:20 PM
t2d2
t2d2's Avatar
I'm not sure about the part numbers, but the height of the glass and the regulator rail changed in '94 or '95. I think it was a mid-year change.
If you put the newer glass in a '92-94, it won't roll down all the way. (It stops about an inch shy.) I suspect you could put in the corresponding newer regulator and get the full travel, but I don't believe that has been confirmed by anyone.
Old 02-14-17, 06:42 AM
Modenaro
Modenaro's Avatar
Another reason I am asking is the #33 part is available at several places. Best price under $100.00 shipped.
The #32 part is not as easy to find, and closer to $150.00 shipped.............
Anyway I can find out if the newer part was an improvement over the older part number?
Some sites list the 69802-24033 as fitting 92-94 SC300?
Hmmmmmmmmmmh...
Old 02-14-17, 09:51 AM
Modenaro
Modenaro's Avatar
Bought the #32. Guess there not the same.................
Old 09-24-20, 11:50 AM
94V8coupe
94V8coupe's Avatar
Question Same problem
How did this work out for you? I am in a similar situation. Build date on my car is 10/'93.
Thanks!
tman6925
01-31-19 12:49 PM
Flygfsh
SC- 1st Gen (1992-2000)
05-25-16 08:25 AM
jaseinatl
04-11-10 02:42 PM
VikH
RX - 1st Gen (1999-2003)
08-12-08 07:54 PM
Quick Reply: Window regulator 69802-24033 or 69802-24032?
