Turbo for 2jzge
Bluegr*** Performance
Depends on the manifold. I'm pretty sure the Performance Factory piece will clear the dist. with almost any t4 flange turbo. But that would have to be verified. A 4" inlet will be too big with almost any other manifold I think. The Sound Performance piece may be an exception but I believe they have been with 3" inlets. You should double check directly with SP and/or PF if you're serious.
I've got a 60-1 using an on center backhousing with a 4" inlet on a toyomoto manifold. It's a tight fit but it works.
70 front and a 81 back housing.
Wayne, is that 427rwhp with the Toyomoto headgasket (I'd assume)? I'd think the 60-1 with .81 on the back would do more like 475rwhp at that boost level. SP runs the 60-1 at 20-23psi with lowered compression. Seems like a very conservative tune on your car. Unfortunately the efficiency starts downhill at around 18psi. Still, it would seem like you've got a good 4psi to go, and more on race gas.
When we first put the car together I had a .69 backhousing on and then later I went to an .81. Never dynoed it with the .81. Might have gotten more out of it.
