SC300/2JZ-GE Fan clutch removal and blade torque?
https://store.snapon.com/Standard-Ha...h-P633882.aspx
Extra long double box end wrenches are perfect for situations like this. This is easily one of the most useful wrenches I have ever used.
I have an old torque wrench handle from a broken torque wrench I took apart that I use as a slip on cheater bar, since one side is round and one side is oval, the oval side I can slip over the small box wrenches and the round side I can slip over ratchets or my long breaker bar if it comes down to that. comes in handy for breaking those bolts loose in tight areas but that long box wrench above is looking really nice actually
Just want to chime in about how important these torque values are.
I must have taken this fan off and put it on a million times, but the last time I overtightened one of the nuts, so now I'm sitting here trying to figure out how to get it off, while the nut spins freely on the bolt without moving up or down.
I'll be undertaking this pretty soon, so.... question: do I need to go ahead and do the water pump as well, since I'm already doing the fan clutch? I've heard not changing these at the same time can cause one or both to fail at a quickened rate. And for someone like myself that's handy, albeit has a somewhat limited amount of wrench time, are either or both of these worthwhile endeavors to do on your own?
freshmoney
GS - 1st Gen (1993-1997)
10-17-11 05:44 PM
