5 speed swap SC400 Los Angeles ?
Old 04-02-16, 06:42 AM
snakehead
snakehead's Avatar
Default 5 speed swap SC400 Los Angeles ?
I'm looking for a quality shop to swap in my R154 manual into my 1998 SC400,
Where the best place to go in the Los Angeles area ??
Thank you in advance
Old 05-05-16, 04:28 PM
vegasgs400
vegasgs400's Avatar
very interested to find out
Old 05-05-16, 11:07 PM
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
You may run into some issues with this passing smog. No one has tried that yet. snakehead, you will need to follow Cartmill's 1998 SC300 W58 swap thread to cover the backup light fix for reverse and you will need to remove the transmission shift solenoids from your A650E automatic and secure them somewhere in or under your car leaving them plugged in so that the ECU gets its signals.
Even then, it's unknown what you will encounter when you try to smog it in CA.
travi19
SC- 1st Gen (1992-2000)
03-27-14 11:07 AM
gleich5
11-12-13 07:15 PM
kpkim01
12-07-09 06:59 PM
Quick Reply: 5 speed swap SC400 Los Angeles ?
