Can't find engine block drain for coolant(COMPLETE coolant drain)
Old 03-24-16, 06:07 AM
river
river's Avatar
Default Can't find engine block drain for coolant(COMPLETE coolant drain)
First thing I want to state that I'm a noob to these forms and Lexus in general. However, I'm eager to learn more from the help of y'all.
I just bought a 1995 SC400 from a previous owner that left her sitting for about 1 1/2 years. Now it's time for a coolant flush...(yes, I'm aware there are other discussions about this, but I couldn't resolve my issue based off of those descriptions and I'm desperate for a solid answer). So of course there's the pet lock on the bottom driver's side of the radiator, which I've found and drained(maybe 1/4 of the coolant) then I started looking for this infamous engine block drain, but I can't point it out when I'm laying under the car.
So question #1: Could someone reference me to a diagram or picture maybe that could help me? Been Googling for the answer but to no avail.
Went ahead and yanked off the lower radiator hose, thinking that would get the rest out, but that only got another 1/4 out of the system.
Question #2: is it really necessary to use the Toyota red coolant? Or will green 50/50 universal from O'Reilly's do me just fine?
Please help 😐 Thanks in advance!
Now
Last edited by river; 03-24-16 at 06:10 AM. Reason: To be more specific on the matter.
Old 03-24-16, 01:19 PM
Sc400NL
Sc400NL's Avatar
indeed if you drain the radiator you only drain a smal amount of coolant
(pics are of a LS400 but same engine ofc )
the right side drain plug
the left side
from my own experience i can tell you that its not easy to reach those plugs with a normal extension wrench
use the red coolant
over here we call it G12 coolant and it is pinkish
Old 03-24-16, 02:50 PM
t2d2
t2d2's Avatar
Try opening the filler cap on the thermostat housing. I get 5-6 qts out that way just draining from the radiator.
Old 03-24-16, 03:51 PM
CatManD3W
CatManD3W's Avatar
Radiator should have a valve on it on bottom drivers side......remove radiator cap first....it will allow the coolant to come out much faster
I get over a gallon of coolant out by doing that....then to get rest out you can pull off lower radiator hose to catch the rest.....be sure to have a big enough bucket to catch it all...
SlkySmooth
03-01-19 04:10 PM
evident
11-21-18 01:13 AM
guycar778
06-30-14 02:34 AM
statix
RX - 1st Gen (1999-2003)
07-25-06 08:47 PM
The Ikon
SC- 1st Gen (1992-2000)
30
05-31-02 02:04 PM
Quick Reply: Can't find engine block drain for coolant(COMPLETE coolant drain)
