power steering cooler for Drifting sc300
hi so after a few hrs of drifting my power steering cooling fluid starts boiling out.
anyone here have experience with aftermarket sc300 power steering cooling solutions? is there a way to improve the oem cooling?
I found several derale power steering coolers online. Are you talking about this one?
http://www.carid.com/derale-performa...mpn-13212.html
^^ I've heard of using SC400 trans coolers as well.
I liked Stu Hagen's PS cooler setup on SF: he built a custom bracket and mounted a Hayden 678 transmission cooler in the driver's side bumper duct at an angle. I bought one of those but haven't done the setup for it yet.
I'd imagine a factory SC400 trans cooler is easier since it's bolt-in pre-existing on V8's? With an SC300 however I'm not sure if it might conflict with the existing PS cooling lines in the same location or if it would just replace them altogether...
If you have that PHR line going straight from the pump to the rack... where do you have the PS cooler connected? Sorry if that sounds confusing; I've not taken a look at the connections myself.
