1JZ Fuel Lines for 500WHP+
I couldn't find no defnitive answer on this:
If I was to run about 500WHP on a 1JZ - can I use stock fuel lines (soarer TT)? If not, what sizes do I need for feed/return. Pump is going to be a walbro 400.
Yes, I ran a single stock line with a 485, Bosch 1000's and a made about 600RWHP before blowing a W58 to hell. Another buddy made 676RWHP with a single stock MKIII Supra fuel line (smaller than the SC) and a single Walbro 485. Both were on E85...
Just use a -6AN to 12X1.25 adapter at the firewall fuel fitting, and the stock return line.
Best way to get the fuel filter off when stuck, is to leave it bolted to the chasis and buy a flare wrench. If that doesn't work Vise grips have yet to fail me. If it's super rusted you can buy a brake line flaring tool, or even rent one from autozone. That would allow you to cut the line off and re-flare it.
They are pain a lot of time, especially without a lift, The one I did today, came right off with a regular box head wrench. It's the first out of 20+ that just came right off. Also re-threading the fitting to the OEM filter is a pain as well and can strip, make sure to take time to thread it correctly. On the adapter use liquid Teflon.
yea I tried everything you said weeks before, tried soaking it with rust solvent, no go. had all that stuff for flaring and a repair-fuel line on my to-buy list until I thought: are my fuel lines even sufficient?
the car is 25 years old and has probably never had the fuel filter changed, so it is bad.
maybe I just do the feed line with -8AN and leave the stock return. Repairing and improving the stock line (banjo bolt end) wouldn' be much cheaper, I think.
LEXXIUM (10-31-18)
Biggu
SC400 / 300 Classifieds
12
01-29-12 06:15 AM
