O2
O2
anyone running these???
"Amazon: PartsSquare 4pcs Oxygen O2 Sensor 234-4169 234-4603 Upstream&Downstream For Lexus SC400 LS400 4.0L: Automotive"
are this the correct parts #
found this on an old post are these for the SC400?
DENSO numbers I found: 2344138, 2344630, 2344167 (2)
Thank you for your support!
I looked around and I am getting different part number of a set of O2
Retrieve code 21, I am sure after that I will get another code over 250 K
So want to ensure I am getting the right part number for Denso preferably but the first 3 are all 4 for under 100 dollars...
Last edited by KahnBB6; 02-18-16 at 04:04 AM. Reason: LeXLUIS: add info - KahnBB6: Removed direct outside link but left description.
Moved to Performance and Maintenance and removed direct Amazon link, (sorry...).
LEXLUIS, I personally haven't had experience with that brand O2 sensor. Maybe someone else has, though? Personally I'd stick with the factory Denso P/N's and just shop around. Have you tried Carson Toyota, Pembroke Pines Lexus, Lexus South Atlanta or Amayama?
(Is been a While since I been active on the forums 2004 in fact at SVT
After much looking around I came up with only two part numbers
upstream 2344211
downstream 2344619
Out in the WEB and based on year or model part # changes and I was confused as to upstream bank 1 # was different than upstream bank 2 #
however Downstream is the same number for both sides.
It seems to me and correct me if I am wrong that there is only two part numbers.
I will give those reference a shot and thanks for your assitance
