Any of you electrical gurus, looking for a way to activate blower on high with one
Old 01-15-16, 04:14 AM
RXRodger
RXRodger's Avatar
Default Any of you electrical gurus, looking for a way to activate blower on high with one
switch. Will this work?
I know I can activate the blower by just grounding the wire from the relay, and I should be able to put 12 volts on the transistor to get it on high, but my question is can I use the 12 volts from the relay as my 12 volts for the transistor? I just need to be able to hit a switch and it come on high, at least that is the optimum for what I need.
This is on a 92 SC300 if it matters.
Old 01-15-16, 11:50 AM
Kris9884
Kris9884's Avatar
Hmm no idea, I just set the **** to 70 all day, every season and it does the rest..
Old 01-15-16, 03:12 PM
RXRodger
RXRodger's Avatar
Default Excellent input
Glad you could contribute to the thread,
Old 01-17-16, 09:19 PM
estomax
estomax's Avatar
it looks like if you just ground the L-R wire coming out of terminal 1 of the blower motor then it will turn on full speed. seems like an easy thing to check also then just wire that to a switch and ground it out as needed..
what triggers the heater relay on top? maybe you just run your switch off of that and permanently ground the blower motor terminal 1 wire.
are you trying to bypass the whole climate control box?
cheers
Marko
Old 01-18-16, 07:57 AM
RXRodger
RXRodger's Avatar
Default The climate control and all of the dash is gone
This is in a stripped race car. I was looking for a way to turn the blower on and have 2 speeds with a dpdt toggle switch. I could do what you said on grounding out of blower motor but that would have been switching full motor amps, need to avoid. I figured out I could put the 12 volts out of the relay across the transistor to get high speed, just ground the relay directly to get low speed. However, as I was hooking up to my new switch panel, I screwed up and shorted the input to the transistor to incoming power to my kill switch and it must have fried the transistor. So, I put a bypass loop in the plug to/from the resistor and switch the wire coming from the relay to ground to get high only. So, I didn't get all I was looking for but only having high speed will work. All I am looking for is the ability to switch on the defroster when needed during rain or foggy conditions during a race. It will work like I have it now.
Starrk
SC- 1st Gen (1992-2000)
09-18-14 04:24 PM
Superjatt
01-24-12 08:32 PM
cmc07e
10-21-07 02:14 PM
snboarder8
12
03-13-03 03:14 PM
Quick Reply: Any of you electrical gurus, looking for a way to activate blower on high with one
