1JZ Afr all over the place.
Hello all, I recently installed a wideband on my sc to see what my 1j is doing. When cold, it idles and cruises great in the 14s but under boost it dives into the 10s. After driving for a little bit it seems to have periods where it'll richen up, idle in the 13s and cruise in the 11s and 12s but this seems to come and go kinda. Then today after driving for maybe 30min and doing some pulls it started to cruise lean in the 15s and idled at in the 17s until it maxed out and I shut the car off and here I am ha. I'm new to widebands and afrs so I'm not really sure where to start troubleshooting. I've browsed around online but haven't really been able to find anything relateable. Any help is appreciated, thanks!
Under idle these cars like to go into the 14.1-15.3 area. Under decal, the injectors turn off so it goes super lean. 10s are not uncommon for these ECUs. Toyota really tuned them conservatively. That's why its so common to see bolt-ons without a retune on these turbo platforms.
For lack of better reason, I will just leave the generic "replace your capacitors" comment and walk away
The 1JZ has a fairly well described part throttle mid-upper RPM lean spot that's exacerbated by any breathing mods. Especially large intercoolers and aftermarket downpipes.
I'm not sure about a rich spot. 1JZs do commonly ride in the high 10s at WOT higher RPMs but that's just Toyota being a grandpa.
Best cheap fix? SAFC.
JTJerryls400
Performance & Maintenance
10-17-06 01:23 AM
