Misfire help!!!???
Old 12-10-15, 07:05 AM
Kingunis
Kingunis's Avatar
Default Misfire help!!!???
so recently my 92 sc400 started misfiring. Im pretty sure its only misfiring on one cylinder but i cant figure out what is causing it. Its not always a constant misfire though sometimes it does and sometimes it runs just fine. Usually when i start it for the first time each day it runs fine and then slowly you start to hear it misfire every few seconds and then after a while it picks up, while driving the car its 50/50 on running fine and misfiring. I have checked the wires with a multi-meter and they tested just fine also im assuming the distributor caps are good since the wires are giving off spark, plugs seemed to look ok when I pulled them just normal wear and tear on them. Im not sure whats causing this or even which cylinder its doing it on so i can pin point my problem. There is no CEL and no codes to pull, although there used to be a code for the TPS and I was gonna replace it but then the code went away. I have already replaced the MAF. the car has 240k if that helps.....any suggestions?
Old 12-12-15, 12:24 PM
Bankswood
Bankswood's Avatar
Had a very similar problem in my SC400. If you haven't replaced your coils recently I would definitely do that first. Corrected my problems
vmichelle
04-15-24 01:34 PM
jchrisf
15
08-30-17 02:15 PM
aznsupra
01-22-16 07:24 AM
Austin2048
21
08-01-14 12:29 PM
PAWTECH69
02-24-11 08:47 PM
Quick Reply: Misfire help!!!???
