Gte ecu swap transmission options?
Old 12-02-15, 10:57 PM
sharkbark
sharkbark's Avatar
Default Gte ecu swap transmission options?
Hey guys, I have a 92 sc300 auto na-t running 10 psi I blew my turbo and am now in the process of installing an hx35. Anyway I was looking to upgrade from my safc 2 to a non vvti aristo gte ecu. I have a pretty good idea on how to swap the ecu, injectors, minor rewire and so fourth. However, I'm stuck on one thing if I use a non vvti aristo ecu, can I install a vvti aristo trans? I want a transmission that can hold 400hp without having to worry too much about it breaking. I wish I could find a non vvti aristo trans but they seem to be rare can anyone help please?
Old 09-26-16, 07:43 AM
SupraMn
SupraMn's Avatar
Have you found any information on this? Been looking into doing something similar and can't find definite information on it. I've seen people swapping out valve bodies but nothing quite like this.
Old 09-26-16, 08:50 AM
Ali SC3
Ali SC3's Avatar
gerrb would probably know if the wiring is similar or not, I have a feeling it isn't a straight swap to wiring a vvti trans into a non vvti ecu. you probably just want to find a non vvti gte auto trans. they are pretty common actually check the different forums and online etc.. or post a want to buy WTB, some people just have them laying around.
Old 09-26-16, 09:22 AM
gerrb
Super Moderator
gerrb's Avatar
they are not same ... wiring and connectors are different .. but doable .
Old 09-26-16, 09:23 AM
gerrb
Super Moderator
gerrb's Avatar
they are not same ... wiring and connectors are different rather not exactly the same .. but doable with some work !
Golden95SC
11-17-16 03:44 AM
spoolinmk4
IS - 1st Gen (2001-2005)
07-08-14 05:09 PM
TURBO819
SC400 / 300 Classifieds
11-18-08 05:24 PM
Quick Reply: Gte ecu swap transmission options?
