LSD install: pinion gear removal necessary?
Old 11-30-15, 07:28 PM
JesLet
JesLet's Avatar
Default LSD install: pinion gear removal necessary?
I read the repair manual and also like to clarify if removal of pinion gear is a must. I think it only need to be pressed out if the pinion gear and or shaft is out of spec when using a dial for runout.
So, if it checks out i should be able to drop the LSD without touching the pinion gear? And of course i need to check backlash, runout, install new side bearings, o-rings, etc...
The LSD i got, TOMEI 10-bolt for Auto 3.26 ratio
neomacz
08-26-15 08:06 AM
LEXSOOS
Performance
19
10-30-06 10:03 PM
SC400DRFT
09-16-06 06:05 AM
clubaddict
08-25-05 05:39 AM
Lexus GS3
Performance
11-26-04 05:37 PM
Quick Reply: LSD install: pinion gear removal necessary?
